Stock '85 Civic, Stay stock, or swap?JMD-123 05-26-2006, 09:10 PM Hey, i have a bone stock '85 civic with a broken camshaft, i have another stock motor to put in it, but i know they only make ~70 horsepower. Is there a cheap motor swap that i could perform? (i'm talking $300-550) Or should i just shove the stock motor back in? Any help is much abliged. Greenblurr93 05-27-2006, 10:45 AM could do a mini me, or swap a d16z out of an EX/SI model. londa hover 05-27-2006, 06:56 PM the most common cheap swap is a jdm d15b vtec longblock from hmotorsonline.com for $430 comes with 130hp and then you can turbo it for less than $500, and have around 200whp JMD-123 05-27-2006, 08:31 PM Thanks guys, i'll look into all those suggestions, i fugured there had to be something i could do cheaply. 70 HP is a bit of a change from my 335 Horse 350 chevy truck. What is the approx mileage on each of those motors? If its around 20-25 it sounds good. Silver1gRex 06-01-2006, 07:16 PM if u have a 85 si civic then its 91hp D15A3, other wise its a dx, right around 70hp D15A2, u might even have the 1.3 try redpepperracing.com for more info -Glenn- londa hover 06-18-2006, 03:49 AM if u have a 85 si civic then its 91hp D15A3, other wise its a dx, right around 70hp D15A2, u might even have the 1.3 try redpepperracing.com for more info -Glenn- the d15b long block is gaurenteed les than 35k on the motor. i made 197whp on mine with a small 16g on 10psi. bone stock/stock injectors/intake mani,internals.. with hf mani. im hoping to make about 230 with a blox mani/arp head studs, and 12psi.. will let you know in about 3 weeks Automotive Network, Inc., Copyright ©2012
