wich camshaft to buy for d15b?londa hover 05-25-2006, 11:02 PM hello people, i just blew my motor, it was a b7/y8 mini me, with a small 16g with 7.5psi boost. it had 152,000miles on it, with jsut a base map. it lasted all year and i was pretty happy with it, until i took it to the track and blew it up on my 5th run. Anywho, I just ordered a d15b longblock form hmotorsonline.com and im looking for a camshaft that will spice up vtec a bit. when i put the y8 vtec head on, i wasnt very impressed, i really couldnt tell any difference, mabie 10whp at the most. i hear most peaople like the zex cam for sohc, any info on wich camshaft i should get given my setup would be appretiated. I want to keep this set up cheap simple, so the motor will stay stock. other than a 255walbro fuel pump. and a camshaft. This time i will dyno tune it, also will be using Neptune EMS. Also alot of ppl are making 230whp on a stock sohc. how is this possible? my friend has a d16y8 with a 14b and blew his hg on 10psi, then got arp head studs and warped the head on 12psi. wich could only be making mabe 210whp max. londa hover 05-27-2006, 07:05 PM Wow this site died fast! guess all the honda guys have all moved over to H-T civicHBsi91 05-28-2006, 12:40 PM Your right it did pretty much die, but people were getting those numbers from their tune, a good tune = good numbers and reliability, good decent parts also help. You can't always throw a junkyard setup together and hope for the best numbers, im sure it's possible but you get what you pay for. Automotive Network, Inc., Copyright ©2012
