Doea anyone know how to change the gear shifter bulbs?BIGANT 07-26-2002, 08:28 PM :confused: Does anyone have pictures or know a website that shows you step by step how to change the bulbs by the gear shifter? I own a '97 accord LX and at night I can't see a thing. How many bulbs are down by the gear shifter? Thanks for all your help, Ant tenguzero 07-27-2002, 12:19 AM I can't tell you much about the bulbs themselves, but I can tell you how to get in to the console to check it out. Open the armrest, pop out the plate at the bottom, remove the screws under it. Next, take out the cup holder, unscrew those 2 screws, and the third screw on the edge, pointing toward the shifter. Slide the whole console back and up. Now you'll see two screws at the base of the shifter console, unscrew them, and you should then be able to pop out that whole shifter/radio/coin drawer console plate (after you take out your radio) Now you can get a gander at the underside of the shifter area. Hopefully this helps? Automotive Network, Inc., Copyright ©2012
