Need Help With Xplod Head Unitfiberglasscivic 05-25-2006, 12:12 AM Ok, I just bought a Sony Xplod XAV-7W off ebay but I need the wiring harness for it. If someone has an Xplod head unit that has the 16 pin wiring harness or close to it, I would appriciate the color to pin code for each pin so that I can make my own. The wiring harness doesn't have to be from the same unit as mine, here's the colors. White White/Black Gray Gray/Black Green Green/Black Purple Purple/Black Black Yellow Red Orange/White Light Blue Blue/White Blue Light Green Thanks for the help! vnvp408 06-02-2006, 03:39 AM I have a Sony Xploid cdx-M8800 if you this it is the same then i can help but how to discribe the pins to you on where it goes? nitebeest 06-02-2006, 01:02 PM The pin numbers go from left to right, top to bottom. As if your reading from a book. 1 2 3 4 5 6 7 8 9 10 11 12 13 ... Doesn't necessarily only have 8 pins at the top, but you get an idea of the count. vnvp408 06-02-2006, 10:37 PM Good Idea! well here is what mines looks like 1=white , 2=green , 3=purple , 4=grey , 5=blue/white (Amp Rem Max 0.3A) , 6=blue (Ant Rem Max 0.1A) , 7=red , 8=black 9=White/black , 10=green/black , 11=purple/black , 12=grey/black , 13=light blue (ATT) , 14=orange/white , 15=blank no color , 16=Yellow Good Luck With It! fiberglasscivic 06-02-2006, 10:44 PM turns out even xplod tech support doesn't know what they're talking about. They told me that I could use my current harness to power this one but the wiring is set up different and the plug is too big. I'm just going to spend the $50 on a new one because it's worth it. I didn't spend but $200 on it and it's worth about $1000. Automotive Network, Inc., Copyright ©2012
