| Performance Discussion about performance modifications and issues. |
05-24-2006, 08:37 AM
NA Performance RB26
Hi all,
Found this forum via google and it looks like there are plenty of knowledgeable people here.
I am looking to fit an RB26 into my 240z. Seems the logical engine to use.
I am however not a big fan of turbos, and to keep it more in keeping with the 240 I'd like to do it NA. Now I know the Skyline comes in NA form (GTS isn't it?) but I'd like to make some really good power.
I have looked at using the RB30 bottom end from Oz, and the OS Giken kit, and the stroked HKS kit. The Giken kit is a lot of money really, which is fine if you are making 1000hp, but my NA won't. I like the extra capacity of the RB30 block and so I could make my own Giken style kit, and I'd like about 500bhp ultimately so it wouldn't be overly stressed.
Well anyway, if anyone has any experience of this kind of thing, any links to engines other people have built with the same idea, or any stats on the standard GTS engine (which I can use and then hot up??) I'd appreciate it.
Thank you for your time,
Russ
05-24-2006, 04:34 PM
Re: NA Performance RB26
Here are some of my thoughts:
Firstly I'd like to use as many Japanese parts as I sensibly can. I am not willing to throw money away just to do this so the rule isn't written in stone, for instance the ECU, I'd like MoTec, and I know the instructions will be written in English. Now maybe there is the Japanese equivalent, but I may not be able to understand how to use it or the software
Fuel: 95 RON probably.
ECU: Motec, or equivalent.
Head: RB25??? I need to up the compression, something like 10:1 would be nice. Obviously worked on (flowed/valve job etc)
Block: RB30
Inlet: Standard throttle bodies??
Ok now I'm lost as I'm not a turbo man and I get confused
I'd love a sequential box, OS Giken again? But I imagine that'll cost as much as my engine  Can is to be used for road, track and strip. Nothing serious so a very fast road set up would be nice, don't want a on/off racing clutch or anything though. Not sure how that works with a sequential set up anyway?
05-26-2006, 05:22 AM
hey mate im from oz here.rb26s only came out in turbo form. the 3 litre you r refering 2 doesnt have a lot more power than your original motor,plus they r getting real old now[86-87]. easiest motor for you would be an sr20. source an import crossmember and theconversion is simple. turbo or non turbo your choice. my advice would be to have a drive of a few turbo cars so u can decide if u want turbo
05-26-2006, 05:25 AM
Hi mate,
Thanks for taking the time to reply. The Sr20 is a no no, four pot and I wan t a 6  Sort of had the feeling the RB30 would be getting old now, but I could use a modern head.
I've had more success in this discussion at
http://www.skylinesaustralia.com/for...owtopic=119495
Maybe you'd like to take a look.
Cheers
06-20-2006, 06:56 AM
You wanna make 500 hp out of a NA engine not bigger then 3 liters? That means you need a high reving engine. (take the NSX engines for example). A high CR (11.5:1) and therefore high octane fuel. I think you need an adjustable length intake.
And you are gonna use it as a daily drive? Then I assume you want some low end torque also?
In my opinion (but that is only from my point of view) 500 hp is a bit to high for an 3 litre NA engine in combination with a 'daily' drive. (but I don't say it isn't possible, it can be done with the right amount of money. And as you talk about OS giken that doesn't seem to much of a problem) I have my doubts by the low end torque (I don't think you wanna rev the engine to 4500 revs/min everytime you pull away from the traffic light.) in combination with high power.
This is not ment to discourage you.
Derby
(I hereby apologise for my reaction if I understood something wrong)
If there was one tiny little thing other then the rest, imagine the power it would have.
06-20-2006, 08:11 AM
Hi,
Thank you for your reply. No no, I'm not the sort of person who gets upset when I don't hear what I want.
I was hoping on the holy grail of 400bhp, and the car will be high days and track days, not a daily at all.
High revs, high octane, high comp, high tech. That was the plan basically. Basically a few people in my club run 2.8s with ITBs, trick ECUS, and 30yr old head designs (SOHC, 12v 6 pots) and make 250bhp. I was *hoping* with 24v, VVT, twin cams, and better flow I could see 400bhp. I will probably only run 99 RON as that's what is commonly available here so I may need to back off on the comp a little?
Some low end would be nice, 4500 would be above what I want as the car will see some traffic no doubt, and I'd probably end up killing expensive clutches. Depends on how tall first gear is I guess, was going to go for a 4.11:1 rear diff or something as I intend to do some strip work and the guys in the club aim for about 4:1. I guess it'd be different if you have more power though and I've no idea of skyline gear ratios.
Anyway I like the Skyline Z tune RB26, that was stroked to 2.8 which might be the way to go.
Money doesn't grow on trees for me, but this is a long term project so it just means it takes longer. I don't see the Giken kit to be good value for what I want really, I think I'd be better off with a stroked RB26, and the money saved could be spent on better (lighter) internals.
Cheers
Russ
06-20-2006, 09:00 AM
Good to see you are up to an open discussion.
Te start with what you said last. Lighter internals are the way to go for high reving engines. I think the rb26 will rev up to 9000 with some work done to it. But I think there will be people around that have more experience with that.
About the 4500 revs/min for pulling away is over here a signal a granny is driving a car. It is all about the expectations I guess
The problem is with the 99 ron or something like that is that I don't know what to compare it to. Is it comparable with the 98 octane number in Europe?
An CR of 10:1 or 10.5:1 is nice for an NA engine. Then there is some safety margin for higher intake temperatures and so on.
About the 400 hp. That is more realistic. The BMW M3 (e46) pulls 343 hp out of a 3.2 six cil line engine. And BMW Motorsport has the reputation to have the best engine tuning capabilities for in-house tuners. I think you should take that engine as an example when you start tuning your engine.
http://www.bmwworld.com/engines/s54.htm An overview of the s54 (e46 m3 engine). I don't have to remind you that BMW has a big budget, but that have one big disadvantage over you and that is emissions.
And if you have a high reving engine with low torque you can compensate for the low torque with short gears. (Honda for example. Very low torque but because of the huge rev range a short gear is sufficient.) For a nice top end speed i would go for a 4:1 final diff with some what longer 4th, 5th and 6th gears.
Just say what you think about it. Having clear what is possible and how to do it makes building an engine more easy.
Derby
06-20-2006, 01:08 PM
High end horsepower sucks! I have a boss 302 that has to rev to 9000 just to get the power out of it, and its horrid on the street. For the track is another story.
I think Derby is correct, 400hp would be a much more realistic goal, and that is at the crank, without making the engine a complete dog on the street.
That is why turbos are so great, you do not have to run a huge cam to make huge power, and your still able to keep the car streetable.
With a V8 its a little different, because you have the cubes to play with, but limiting your self to a 3.0, your going to have to spin it to the moon for power, that is plan physics.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
06-20-2006, 01:15 PM
Hi,
I think my original 500hp must have been a typo, I asked for 400hp on every other forum. I don't believe 500hp would be realistic with normal ron petrol
I think 99 RON is 99 on the continent, RON is just the measurement, see http://www.millersoils.net/pdf_downl..._explained.pdf for explanation (RON vs MON etc).
We can get 108RON here but it's very expensive and not as readily available. An option I had considered is bio ethanol as a fuel, I think that's about 110 RON, but I know nothing about it... yet
If I wanted easy horsepower I wouldn't be considering an NA RB26, I'd drop a SBC in or a turbo engine. BUT my car has a NA straight 6 engine in it, a Datsun L24 to be precise, the RB engine is obviously from the same manufacturer, again a straight 6, and so it has the right soul for my car. I could do turbos, but that wouldn't be in keeping with the L24. Plus big throttle bodies are naughty!
Can anyone recommend a comprehensive RB26 engine parts website please so I can start eyeing up products/prices? Also who'd make the most appropriate stroked crank? HKS? Or try and get the NISMO one?
06-20-2006, 01:36 PM
About the fuel...if you go for bio ethanol (which i personally recommend for future HP increases) think about the rubber sealings in bearings, fuel lines. They have to be tested to be resistant to bio ethanol.
About parts...HKS, NISMO, all build parts for turbo engines, which are stronger then they are light (big pressure above the piston). Strength is the main design demand. Lightness is not. And you need lightness.
I think you have to see what you can do with Honda/Acura parts...But that won't be easy.
Let me know what you have found.
Derby
06-20-2006, 01:39 PM
www.takakaira.com or greenline
I know where your coming from on the build, sounds like you have made up your mind, its cool to be different
Hence me putting a turboed V8 in a GTR
06-20-2006, 01:48 PM
Check this out, it talks about the break down of the silicone when using meth injection.
http://www.turbomustangs.com/smf/ind...?topic=64229.0
06-20-2006, 02:43 PM
I have to say that I would be much impressed by a 240Z revving up to 9500. That makes an interesting competitor at the traffic light  I speak from experience that shifting late cos of high revs is an advantage.
And about the bio stuff. Most modern diesels (Volkswagen TDI) have sealings and hoses that are vegitable oil resistant. But the older engines won't. And the damage can be serious.
You can also try to run your car on LPG or even better CNG. CNG has a octane number of 114. And if you have a good ECU setup it can detect the octane your running on.
Fast diesels are out. Sportscars on CNG are in
Derby
06-20-2006, 02:55 PM
Derby
Yep fun, except if you are driving normal
CNG Sportscars just might be the next big thing
06-21-2006, 03:19 AM
Thanks chaps. Does anyone have any good bio ethanol links? I guess I could build my engine with biothanol in mind, and still run it on petrol, and switch to bioethanol when I feel like it running different engine maps? I'm a bit of a geek so intend to spend a fair wedge on a top MoTec ECU or something, really fancy plugging my laptop into my car and checking it all out.
Thank you for the links, and http://www.greenline.jp/ is Greenlines website. I will spend my break time perusing that
Yes 9500 rpm 240zs would be awesome, even if it's not as fast as a turbo'd car it'll sound absolutely awesome (I think/hope). My other car I'm working on getting is a 68 Dodge Charger, so I'd have a high revving jap car and a (blown) yanky v8, best of both then (imho). One day...
I think I'll avoid gas as a fuel for now
