94 ranger 2.3 t-belt replacement help...busa4 05-21-2006, 05:40 PM my neighbor has a 94 ranger with the 2.3 4 banger. he wants me to change the timing belt, water pump, and thermostat. how involved is this? i am a gm guy. i dont know much about fords so i need your help. he told me to give him a price but i dont know the motor or whats involved in changing these parts. any info/help would be much appreciated. bluebug 05-21-2006, 08:52 PM I have had four diferent Ford 2300cc motors. Timing belts are not difficult at all. A surpentine belt makes it more difficult, as the idler pulley gets in the way. You do have to remove the crank pulley and the water pump pulley. Timing cover is held on by 4 or 5 bolts, later models are plastic. After you get the cover off, you will have to line up all three timing marks, as the distributor/oil pump have a gear of their own. There is a tensioner pulley in the middle that has a heavy spring on it. There is a large bolt in the middle of it and a small one just below. Loosen both and push it out of the way, then retighten the small one to hold it there. Remove the old belt and install new one, making sure marks stay aligned. Loosen bolt holding tensioner pulley and let it push against the belt. Retighten it and the large one. Clark busa4 05-21-2006, 10:07 PM seems straight forward. any special tools needed? bluebug 05-22-2006, 07:31 AM No special tools. Clark busa4 05-22-2006, 07:41 AM great!!! give me an idea how much labor i should charge him. thanks for all your help. breakcore 06-14-2006, 10:57 AM it sure helps to have or borrow a pulley removal tool! i just replaced mine, it was all pretty easy, just time consuming. my t-belt broke AND crankshaft sensor had to be replaced. while in there i replaced the water pump and thermostat. my Haynes manual was helpful but didnt have enough pics to help me with that specific engine. i went to the dealership and got a print out diagram after asking where the crankshaft sensor was. that diagram from the dealership helped out a lot. they priced a new Crank Sensor at $310 but i got it at a parts store for $120. the thermostat was very cheap, the water pump was $16 w/ core and i forget what the t-belt costed. i was too busy to put everything back together so a mechanic charged me $150 to do it, but he also replaced cleaned my injectors, changed my plugs, wires and crank sensor. i gave him all the parts needed so he only charged me labor. genesparks 11-28-2006, 09:18 PM I have had four diferent Ford 2300cc motors. Timing belts are not difficult at all. A surpentine belt makes it more difficult, as the idler pulley gets in the way. You do have to remove the crank pulley and the water pump pulley. Timing cover is held on by 4 or 5 bolts, later models are plastic. After you get the cover off, you will have to line up all three timing marks, as the distributor/oil pump have a gear of their own. There is a tensioner pulley in the middle that has a heavy spring on it. There is a large bolt in the middle of it and a small one just below. Loosen both and push it out of the way, then retighten the small one to hold it there. Remove the old belt and install new one, making sure marks stay aligned. Loosen bolt holding tensioner pulley and let it push against the belt. Retighten it and the large one. Clark I just threw my timing belt on my 93 ford ranger (2.3ltr). I am not clear on lining up the timing marks. Could you elaborate. I have the belt on and have figured out how to relocate the three sprockets but I am not sure where to align the marks. I am not even sure where the mark is on the lower sprocket that the harmonic balancer bolts on to. What do I have to line up or where do I have to line up the marks. Any help would be greatly appreciated. Thanks, Gene vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
