won't start
Google
Web AF
1969
05-21-2006, 02:56 PM
i have a 2001 s-10 with 4.3 that acts like it is in gear when you turn the key to start it .
after messing with it a while it starts like nothing is wrong .
would it be a sensor like a heat sensor saying its to hot or oil sensor thinking there is not enough oil or what.
busa4
05-21-2006, 05:45 PM
alarm???? could be a starter disable problem with your alarm.
what are you doing to it when you say "messing with it"?
1969
05-21-2006, 09:40 PM
by leaving the door ajar and turning the key off and on. i can cross the starter over the selinoid and it rolls over. what do you mean by alarm
:banghead:
busa4
05-21-2006, 10:04 PM
do u have an alarm? is it a manual or auto trans?
1969
05-22-2006, 10:32 AM
its an auto trans. no codes come upwhen its put on my computer reader.
busa4
05-22-2006, 12:32 PM
make sure your park switch is adjusted correctly. the next time this happens give your gear selector a good tap into park to make sure it hit the park switch. also try starting it in nuetral when it happens and see if there is a change.
1969
05-23-2006, 09:41 AM
I tried puling it out of park and putting it back in. I also tried it in neutral nothing seems to work. thats why I thought it mite be a sensor of some kind. otherwise it must be the Ignition switch. And messing with the airbag is something I don't want to tackle.
busa4
05-23-2006, 11:24 AM
i would have to say a possible ignition switch failure if you dont have an alarm with a starter disable function.
1969
05-23-2006, 01:31 PM
thank you for your help:)
1969
01-11-2007, 12:10 PM
turned out to starter who knew
Google
Web AF
