kick panel enclosure question
kenwood guy
05-20-2006, 06:21 PM
im looking to add component speakers to my sound system but my door speakers on hold full range speakers (one on each side) im thinking about getting these for the silverado what do you guys think?????http://www.crutchfield.com/S-JELPT2nvTWi/cgi-bin/ProdView.asp?g=182850&I=044K101219 there about 150 for the set is it worth it???
sportin83
05-20-2006, 09:34 PM
ive installed a couple of pairs of these and they look good, but you lose alot of foot room and also i duno how the parking brake will work becasue this will block that.
kenwood guy
05-20-2006, 10:53 PM
then maybe I should i just upgrade the speakers and not add them is it possable to use parts from another silverado door panel?? like yours??
sportin83
05-21-2006, 01:31 PM
just see if you can find new door panels , any tahoe suburban silverado should work. the escalade should to i think. or you could just install the 61/2 components and cut a hole for the tweeter and flush mount it in the door.
kenwood guy
05-21-2006, 05:23 PM
how would I go about doing that??
sportin83
05-21-2006, 11:38 PM
for the door panels i would check a junk yard, and to flush mount the tweeters you will have to remove the door panels and find a spot that is flat and has some room behind it and then get a hole saw bit and put in a drill and drill the hole the size of the tweeter and then install it.
kenwood guy
05-22-2006, 01:54 AM
so then they are the same type of door panal you have right?? i got to do some hunting around the problem I have is that my truck has manual doors and windows so the switch controls would not be hooked up thats why i asked from the begining if i can get the part of the door panel i need and swap the rest of the pieces i could be wrong
sportin83
05-22-2006, 12:07 PM
you might be able to get manual doors, but i duno the other doors speaker grill might be in the way for the crank to work and the switch panels will have switches unless you can find replacement ones.
kenwood guy
05-22-2006, 03:55 PM
I think it might be more easy of i just got the kick panel boxes do i lose a hell lot of leg room??? and on the link it said the e brake has to be bent 1in and a half did you do that???
sportin83
05-23-2006, 04:32 AM
i didnt ever hear about bending anything. i put some in and the people just didnt use the brake anymore and for me i didnt like the lost room, but i am also 6'5" so i need more room than most.
kenwood guy
05-23-2006, 02:45 PM
yea you do!!! im a little under 6'0 but if you look at the bottom of the link it says the brake has to be bent do you know of any other sites that sell these items???
01silverado03z400
05-23-2006, 11:47 PM
I say just upgrade your 6 1/2 and cut out the holes for the tweeters like sportin83 said. Cheapest and easiest way :icon16:
sportin83
05-24-2006, 01:21 AM
i dont know of any off top of my head without searching around. if you can work with wood and fiberglass you could build some kickpanels. i found this link 1 time and has a pretty basic step by step process. http://web.njit.edu/~cas1383/proj/kickpanels/index.htmhttp://web.njit.edu/~cas1383/proj/kickpanels/index.htm
kenwood guy
05-24-2006, 01:31 AM
seems like alot of work for something so small but maybe worth a try??
kenwood guy
05-24-2006, 02:47 PM
has anyone here work with fiberglass????
sportin83
05-25-2006, 03:12 AM
i have played a little but nothing major yet. i know u need to make sure to take your time and wear a mask and gloves.
guumbah
05-25-2006, 09:43 AM
V-e-n-t-i-l-a-t-e
alphalanos
05-25-2006, 09:51 AM
I figured I'd chime in. I've done some work with fiberglass, and it takes a few tries to get it right. Honestly If I were you I would just upgrade the speakers in your doors. Get a good set of component speakers and an amp and you'll be all set. The easiest thing to do is mount the tweet in the door (its supposed to be close to the woofer) and maybe make an MDF ring to hold the speaker. This will allow the speaker to play with nothing blocking the sound path.
Tdragone
05-25-2006, 10:39 AM
Dude; if you're gonna go to a junkyard to get new panels; might as well gut the door and upgrade to power windows. You should be able to take everything you need from the junkyard; right?
All you will have to do is get power to the windows and the rest should be self contained in the door.
I did this on a 2000 ranger for my dad. It was the better part of a saturday at the junkyard; and just a sunday morning to install since I already knew how it went together.
