grinding noise coldsgt calderon 05-19-2006, 10:57 PM my 02 sebring has a grind like sound when cold around 12-1300 rpm on the passenger side. it goes away when warm. i've opened the hood when it does it but i can't hear anything. it even feels like it could be a bad vibration. i had an 01 with the similar problem both have a 3.0 and i couldn't fix it either. any one else with same problem? calisebring85 01-02-2007, 06:13 PM I have an 01 sebring coupe and i think i might have the same problem as you... the noise is a mix of grinding and creaking correct?? the noise comes from the wheel well in my case i had a mechanic look at it with no luck... have u figured anything out yet?? im going to try replacing the front suspension hopefully that does the trick... ill keep u posted... 93pb 08-31-2007, 07:04 PM Any luck on finding this my mom's car is doing the same and it is driving me nuts trying to find it. 93pb 09-02-2007, 09:11 AM Just a follow up it was the lower ball joint assembly on my mom's car. Marc Automotive Network, Inc., Copyright ©2012
