System Relocated, All done!!Pages :
[1]
2
P11GT 08-16-2001, 10:23 AM :D After 8 intense hours, i finally got it all done, and heres the end result. P11GT 08-16-2001, 10:25 AM dont tell me, i know theres a screw missing;) i noticed it after i took the pic, and you will be pleased to know, ive now rectified it:D Heres another DVSNCYNIKL 08-16-2001, 10:27 AM That is without a doubt, the most clever place I've ever seen an amp placed in a car. I'm curious to know exactly how you did that. redvalkrie 08-16-2001, 10:51 AM Wow that is way cool you did a sweet job, it looks very clean! BIG PROPS! Wish I had friends nearby like you! :wave: :wave: :apoke: :jump: P11GT 08-16-2001, 11:00 AM Its hard to explain fully how i did it, but basically, workout what size amp rack you need to house the amp(s) and then make it to a design you like, then install it. It far easier to work on it when its not up in the air and upside down. If you have a look at the other thread, you can see some pics of the amp rack during the making process. I didnt have a camera all the time so i couldnt take loads of pics. Once you're happy with it, then install the amps into it, line into place using ropes, attach brackets to the rear, cut the roof lining so the brackets can pass thru, wire up all the cables and then fix amp rack into place using the brackets. I would strongly advise you to have a good look above the lining first to see if there are suitable points to fix the brackets to. Anthony 08-16-2001, 11:38 AM Nice job :D P11GT 08-16-2001, 11:41 AM Danka !!:D redvalkrie 08-16-2001, 12:24 PM paka!:alien: :bloated: endfro 08-16-2001, 12:34 PM I'm auctually tempted to do that with mine... thats really sweet looking, ive never seen anyone put their amps in the ceiling of the car before. But what if someone thats really tall gets in the back of the car? FREAK! BEHEMOTH! THATS A HUUUGE BITCH. P11GT 08-16-2001, 05:37 PM I dont normally pick up FREAKS!! so i wont have that problem:D does it pose a problem for you??????:D jk dre 08-16-2001, 10:49 PM well, I know all the 6foot plus super models that are always cruisin around in my G wouldn't like it. but, hey it looks super sweet.:ylsuper P11GT 08-17-2001, 04:12 AM well thats where you can use the excuse and get them to lie down on the back seat for you, you know what i mean;) G20RIDER 08-20-2001, 02:05 AM Looks like a job that cost hundreds of dollars.....very proffessional looking.....BTW do you have some type of light in there?:jump: P11GT 08-20-2001, 05:11 AM The raw materials didnt cost too much. The main cost was for the 12 volt fans(x4) which work out around $80 and the Blue LEDs (x45) ive installed internally to light it up $90. I then had to get new cables all round $95 but the wood itself was only around $10, go figure. It looks professional due to the way i wanted it to look. Most of my ideas start in my head rather than on paper, and i tend to think of what and how i want it to look and the best way to do it. Sort of picturing it before its done. Hard to explain. Anyway, still a little finishing off to do to it, i'll take some more pics and post them shortly. P11GT 08-20-2001, 05:13 AM Heres a picture at night, not very good, but you get the idea. bump909 08-22-2001, 05:34 PM first off, that is a really clean looking install. one thing though, even though you have those fans there.. the heat fins on the amps are facing upside down so any heat that the amps give off will just rise back up into the amp, even with the fans on. have you ran into any problems yet? P11GT 08-22-2001, 08:40 PM Im aware of what youre thinking but so far, havent run into any such problems. The amps do have a temperature cut-out, but also have a built in fan which pumps out hot air, which in turn will be ventilated with the external fans. It seems to work no problem, even after a good hard thumping of the system. Swonder67 08-23-2001, 12:29 AM Hey P11, sweet set up. How many watts do you got running through your car right now? do you have caps? if yes, where are they? P11GT 08-23-2001, 05:01 AM To be honest, i dont really know how many watts, if the amps are anything to go by, then one of the kenwoods is 4x150w at 4 ohms and the other is bridged to 1x400w (4 ohms) but im running the JL at 3ohms. I suppose its not alot of wattage in total but the trick to the system is the Pheonix Gold Bass Cube mounted it the boot, which makes a hell of a difference to the Sub, easily doubling the SPL. Ive thought about using a cap but theyre quite expensive here, maybe invest in one later. A nice fancy one with a digital readout. poppy_morenito 08-23-2001, 09:13 AM That is sweet !!!!! Swonder67 08-23-2001, 09:28 AM Hey, what if you gotta work on the amp? Does that plexi come of easily? Did you run the wires right through the headliner? I still can't believe you put the amps on the roof. That's a really smart setup aluke000 08-23-2001, 07:05 PM How is the rack actually attached to the roof? Or are you using cross braces? And does it interfere with the sunroof? P11GT 08-23-2001, 09:26 PM I'll try to answer all the above questions. Firstly, i think i mentioned earlier in this thread, or in the 'any ideas on system location' thread, how i was goona attach it to the roof, but basically, the sunroof runs along a suspended rail, fixed to the actual roof. I just screwed bracket onto that and the amp rack. Secondly, the system has previously been in the car for sometime before. I have the same setup and was quite happy with all the speakers and the sound of the system in general. So i just disconnected all the wiring, left all the settings as before, and just relocated it. The front does come off. Its made of 6mm MDF and had perspex windows for show, but to be honest, there no room to actually do anything, which is why i left the setting as before as i was happy with them. I had to make a series of cuts around the lining for the brackets and for the wiring to pass thru, the wires then just come down one side of the rear pillars and into behind the side support and bootrim where all the connections were rejoined. redvalkrie 08-24-2001, 04:03 PM Hey what type of set up besides the amps are your unning Speaker's? What Headunit? Any crossover/eq? ?????? P11GT 08-24-2001, 04:10 PM The spec for the whole car is listed on www.primeraweb.co.uk , click onto readers cars, kevins'98 GT. Basically, the headunit controls the whole system with its built in electronic x-overs. Anthony 08-28-2001, 04:59 AM And I'll testify that Kevin has a sweet sounding sound system in that Primera, as I had the pleasure of hearing some tunes through it at the weekend. Just when I was thinking that I had my system sounding alright for a change.... :crying: P11GT 10-07-2001, 11:08 AM Time for my next project. I casually went into my local audio shop to ask about this new in dash Kenwood DVD Player, and mentioned that if i got one, i would need one of those Kenwood MiniDisc Slave units, the din size ones. Anyway, as it turns out, they had bought a shit load of them, and because they were last years model, they were selling them for £200 instead of thr RRP £400. The reason why i need a MiniDisc, is because all my music is on them due to my current headunit being the KMD-PS971R, a minidisc player. Without hesitating, i left a deposit for it, and then went home to think about where i could install it. The ideal location would be in the dash, but as there is little space, and without cutting the dash, i had to find somewhere else. Guess what, i looked at the front courtesy light housing, where the sunroof switch is, and thought to myself, why not just put it there, that way, its also suspended like the rest of my system. So ive set about making a new housing for the slave unit and this is how far ive got in 3 hours. P11GT 10-07-2001, 11:10 AM it still need plenty of shaping, and then covered in black vinyl and finished off with a silver cover like the amp rack. P11GT 10-07-2001, 11:11 AM because ive used the original light fitting, i can secure it up the original way to hold it in place. P11GT 10-07-2001, 11:12 AM this is the upright position. Swonder67 10-07-2001, 11:42 AM Will the light housing be strong enough to hold up a head unit? Cuz I know in a P10, the housing just kinda snaps off. I dunno, maybe the P11 uses screws or soemthing. Do you think you got aenough stuff nailed to the ceiling. haha. Nice work though. frogg 10-07-2001, 02:21 PM Hehe, looks nice but I can just imagine that thing smackin you in the head if you get into an accident .. *whack* P11GT 10-07-2001, 09:15 PM Hey guys, i know what youre thinking, about the 'smack in the head' thing :hehehe: but so far, the amps have managed to stay up. The light fitting does click into place, but there are two screws that hold it up aswell. Anyway, im intending on putting some more in just incase it does decided to hit me on the head:D Things are starting to take shape now. Ive made the perspex window for it, and finished off rounding up all the corners. Tomorow, i'll get it covered in the vinyl, then ive just gotta wait till i get the extention lead, and plug it in. Hopefully, it should be done by the end of the week. MoReace 10-07-2001, 09:22 PM All this stuff sounds quite difficult. I wanted to cut through 2 slots in my P10 to make a double DIN slot and put in a monitor. This leaves me the problem w/ the stereo. I can't or at least have never tried to mold fiber glass. Do you have any suggestions? The folding monitors that fit in the single DIN are way too expensive. Thanks P11GT 10-07-2001, 10:33 PM i presume your trying to make some sort of surround for the monitor, then in that case, use MDF (medium density firbreboard) as this can be easily sanded and shaped so it looks like fibre glass. You then need to give it a good coat of primer and then colour it. You can then mount the surround in place using right angle brackets on the rear of if, and onto the inside of the console where youve cut your hole. Aswell, you could then fix a board to it horizontally going into the console to act as a shelf. for your monitor. Hope this helps. Grunter 10-08-2001, 03:04 PM All this stuff sounds quite difficult. I wanted to cut through 2 slots in my P10 to make a double DIN slot and put in a monitor. This leaves me the problem w/ the stereo. I can't or at least have never tried to mold fiber glass. Do you have any suggestions? The folding monitors that fit in the single DIN are way too expensive. Thanks I did an install on a mates P10, frist we moved the heater controls in to the glove-box (which was a bit of work, but it can be done) but then we moved them back and took out the top heater vents, and put head unit up the top, then a TV bellow, with the heater controls at the bottom. greekman 10-08-2001, 11:35 PM p11gt-nice, very nice. that is a very unique system location and your install job makes it look very clean. grunter-did you put the heater vents back in? that sounds crazy moving the controls to the glove box. the whole set-up sounds crazy, but interesting. MoReace 10-09-2001, 01:06 PM I'd love to put them in the armrest console. I don't even think it could be done w/ major cutting. Why is it there. IT IS SO SMALL!!!!! Nothing even fits in it Grunter 10-09-2001, 03:25 PM grunter-did you put the heater vents back in? that sounds crazy moving the controls to the glove box. the whole set-up sounds crazy, but interesting No, the last install we did on that car, we put the heater controls back in the centre consol, but left the air vents out. When we moved the heater controls we went to a wreckers yard and brought the plug and a bit of loom, so we didnt have to cut the factory loom in the car. Hope this makes sence if not give me a yell P11GT 10-11-2001, 08:43 AM Ive fitted the slave unit rack into the car, now just waiting the arrival of the extension lead i need to install it fully. Heres what it looks like at the mo. P11GT 10-11-2001, 08:44 AM another P11GT 10-11-2001, 08:46 AM last one ragt20 10-11-2001, 06:29 PM looking very nice!!!!:sun: :sun: :sun: :sun: Swonder67 10-11-2001, 06:43 PM Wow redvalkrie 10-11-2001, 07:10 PM Dame man u r good! Major props I can't even cut straight!:D P11GT 10-11-2001, 07:24 PM Thanks for all your kind words:D im just surprised no one think that i get this stuff made for me, but i can guarentee you, its all my own work. The only thing left to do is to light up the perspex window, this time, im gonna use neon flexi strips. The Blue LED's i put surrounding the amps have all went off for some reason, ALL 42 except 3 of them that is. So this time, im gonna get these ones. They come in pairs at 16" long for £25, and i need about 3 sets at a staggering £75 :eek: Is it worth it??? You tell me, i got no money and NO SENSE!!! ragt20 10-11-2001, 07:30 PM Originally posted by P11GT You tell me, i got no money and NO SENSE!!! do any of us here have either....:silly2: :silly2: :silly2: nismo_gt 10-12-2001, 01:57 PM Nice work Kev, You've certainly put the work in & it shows ! :flash: P11GT 10-15-2001, 07:31 PM Its all done now, all singing and all dancing, but my shitty little cool-i-cam wont take pics in dull light, so i cant post up the pics just yet. Will do shortly. Next thing to do, is to get some neon cable to light it all up, including the amp rack again. Swonder67 10-15-2001, 08:06 PM Pretty soon, you'll have the friggin steering wheel bolted on to the roof with neon lights all around it, and you'll say, "well, I just wanted an original place for it." What's your next project? P11GT 10-15-2001, 08:11 PM Originally posted by Swonder67 Pretty soon, you'll have the friggin steering wheel bolted on to the roof with neon lights all around it, and you'll say, "well, I just wanted an original place for it." What's your next project? Hey, how did you know that was my next venture??:D ??:D ?? I could sit on the roof, extend the pedals, and hang me feet thru the sunroof and drive it:D Wrap my head with those little fairy lights off my Christmas Tree................ im of to get started!! P11GT 10-16-2001, 07:50 PM heres the finished product P11GT 10-16-2001, 07:51 PM another............. P11GT 10-16-2001, 07:51 PM and another. ragt20 10-16-2001, 07:56 PM looks awesome m8......nice work..........:sun: :D :cool: :sun: :cool: MoReace 10-16-2001, 08:16 PM That is sweet, but where are you sunroof controls? P11GT 10-16-2001, 08:20 PM I knew someone was gonna ask that:D I havent got round to it yet, but i'll extend the wires and relocate that somewhere suitable. Anyway, its getting cold here in the UK so i dont need the sunroof at the mo. But well spotted:D MoReace 10-16-2001, 08:43 PM Thanks, I try. Wanna make some cool stuff for my car? :silly2: P11GT 10-16-2001, 08:45 PM nah, sorry, its hard enough to find time to make my own stuff. Swonder67 10-16-2001, 09:26 PM that thing doesn't block your rear view mirror, does it? You're not gonna enjoy this idea, but why don't you get rid of that plexi and put the sunroof controls there? Bye bye GT-R Automotive Network, Inc., Copyright ©2012
