'91 Ranger no sparkbigj-dog 05-19-2006, 09:11 AM Hi, a friend can't get his '91 Ranger 2wd 3.0/2.9 started. He doesn't have spark, changed the dist., cap, rotor, plugs/wires, and coil. It's got power to the coil on ignition and the distributor spins. We figured we'd check the module next, but we can't seem to locate it. Does anyone have any information or pics of the location? Thanks. Psychopete 05-19-2006, 10:06 AM Hi, a friend can't get his '91 Ranger 2wd 3.0/2.9 started. He doesn't have spark, changed the dist., cap, rotor, plugs/wires, and coil. It's got power to the coil on ignition and the distributor spins. We figured we'd check the module next, but we can't seem to locate it. Does anyone have any information or pics of the location? Thanks. Big difference between the 2.9L and 3.0L. 2.9L should state "2.9L Electronic Fuel Injection" right on top of the intake. It also has a distinctive upper intake manifold with 3 runners. I am not certain about the 3.0L, they did make a 2.9L Ranger in 91. The 2.9L TFI module is located on the back of the distributor. Have you attempted to pull codes to verify that the ECC is working properly? Pete bigj-dog 05-19-2006, 10:16 AM I never checked codes, but supposedly someone else did, and there weren't any. I just looked at it for the first time yesterday. I'm 99% sure its the 3.0. The diagram on the shroud shows the ignition module remotely located, I wasn't sure what I was looking for. I looked up pics on Napaonline, this morning, but I don't remember seeing it anywhere. Looking for a direction to start my search. 12Ounce 05-19-2006, 11:50 AM You might try looking in the maintenance section of the AutoZone website. (I'm doing some work on a 2.9.) The AutoZone website covers both engines rather nicely ... showing some simple tests for both ignition setups. bigj-dog 05-19-2006, 12:46 PM I checked out the site, it claims it mounts on the dist. I'll check into it as soon as I get home. Thanks 12Ounce. I've been on autozone's site before, but I wasn't aware of the maintenance section of it. There's a ton of info there. bigj-dog 05-22-2006, 11:01 AM Found the module, mounted drivers side of the radiator, inside a finned cooler. Still no spark though. Anyone have any other ideas? mtmaurer8ooo 05-23-2006, 01:55 PM Sounds like you may have the wrong animal there. The ignition module on the 2.9 is mounted on the distributor. Post an engineering # off the part you have and I'll see if I can cross it. MM. bigj-dog 05-23-2006, 04:34 PM This is a 3.0, and we had it checked out and it was good and it was a twin to the one O'Reilly's gave us to put in its place. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
