7MGE rod bearingsgenej 05-17-2006, 03:19 PM I'm trying to replace the rod bearings in an 89 w/a 7mge. How do I get the d#%*ed oil pan off? Do I have to remove the whole front end? rhandwor 10-17-2006, 02:43 PM You can try to loosen the motor and transmission mounts and see if you can raise it enough. I've changed them on an 6MGE but I pulled the engine. On the supra if you disconnect the computer harness and pulled it through the fire wall you could pull it with unplugging the engine wiring harness a rough job. Automotive Network, Inc., Copyright ©2012
