dropzone?01_Celica_GT 05-16-2006, 02:54 PM My buddy is selling his dropzome shocks and springs to me brand new(he totalled his car and didnt have time to put them on) for 250$. Are those shocks and springs any good or will they mess something up? superbluecivicsi 05-16-2006, 11:17 PM they are great if you like to feel every single bump on the road. D[X]P 05-16-2006, 11:40 PM dropzone sucks... fiberglasscivic 05-17-2006, 01:13 AM I personally would go with APC lowering springs before I went with DropZone. (Now that's saying something :rofl:) 01_Celica_GT 05-17-2006, 04:54 AM what about the shocks? shocks any good? I need rear shocks so should I install them? vette_7t9 05-17-2006, 11:15 AM just buy the rear ones...its all u really need to curb that understeer haha 01_Celica_GT 05-17-2006, 02:49 PM well this is my problem. When i go around a left turn my wheels rub and shave off my tire. So I thought i needed new shocks in the back. I have 18's all around. So what do i need to stop that? And what is understeer? D[X]P 05-17-2006, 03:04 PM IF you wana go cheap but get quality parts to lower your car just get tein s tech springs and tokico blues springs 01_Celica_GT 05-17-2006, 03:07 PM Alright, I wasn't looking to go cheap. I'll spend the money, but there were offered to me right now and i could put on my car today. So thats why I asked. polacek 05-17-2006, 05:52 PM "When i go around a left turn my wheels rub and shave off my tire" Your camber is out. Try this out. http://www.automotiveforums.com/vbulletin/t32669.html http://www.hondaswap.com/forums/index.php?showtopic=36766 http://home.earthlink.net/~civicex95/rearcamber.html Don't forget to get an entire wheel alignment. Better yet, get a wheel alignment and see what is off before you start. fiberglasscivic 05-17-2006, 06:37 PM I think the problem is wheel size. If those are wide enough and you didn't put spacers on, that would also cause rub. Lowering your car will only make it worse. vette_7t9 05-18-2006, 07:03 PM Spacers. Speaking of spacers, ive been looking for a cheap set of 25 mm for my civic...any help or suggestions? Wow 18 inch is flipping huge!! I wonder how u fit those on ur car? polacek 05-19-2006, 02:29 AM He didn't fit them, they are a rubbin :) 01_Celica_GT 05-19-2006, 07:32 PM Spacers, are those hubcentric spacers or whatever. where do i get those at. and they do fit, because none of the other wheels rub. they are 215 35 18 and the dudes at tiresplus said they are tight but they fit. i thought by putting stiffer shocks on it would help from the car not lean so much therefore not rub. where do i check my camber angle. like what place. oh yeah and im on a laptop and the question mark key doesnt work so i cant use slashes or question marks. vette_7t9 05-20-2006, 10:13 AM get an alignment? 01_Celica_GT 05-20-2006, 03:54 PM thats the only thing i was thinkin but do they align the rear tires? fiberglasscivic 05-20-2006, 09:18 PM You can check the camber by setting the car on level ground and using a plumb (weight on a string). By placing the plumb at the top of the arc of the wheel well and letting it hang almost to the ground you can compare the straight line of the string to the line of the wheel. If the wheel is off then you camber is off. Yes by using stiffer struts you will reduce the ammount of movement causing the camber to change while you drive but by using a set of lowering springs you force the wheels to sit in a position that changes the camber from the stock setting. That's why you see cars that have been lowered 4 inches and their wheels look like this //------\\. If you camber is off the best solution to the problem is to use a camber adjustment kit. Yes I was talking about hub centric spacers. I have no idea where to get them and 18 inches is the largest wheel size you can fit onto a honda civic without making changes to the speed sensors. Because of how wide the tires are they require a hub centric spacer and they reduce the turning radius, especially on lowered cars. 01_Celica_GT 05-21-2006, 01:14 AM is there a certian kind i should get? like do they come in MM or CM or what? polacek 05-21-2006, 02:59 AM Camber for rear wheels. Did this on my civic with no problems. http://home.earthlink.net/~civicex95/rearcamber.html polacek 05-21-2006, 03:01 AM Auto shops can only align toe for the rear, toe and castor for the front. They can measure the degree of the camber though. vette_7t9 05-21-2006, 06:06 AM hey fibreglass, thats a pretty flipping sweet way to measure rear camber. i guess you just need to be mechanically inclined and have some basic knowhow and youre set to do camber adjustments. After all, they did it in the old days with hardly the technology we have these days. And yea, the spacers come in mm. I saw some from eibach i think. I forgot where i saw the 25mm ones, but was kinda hard to find 25 mm...... the only reason i need them is for autocross, i use hot stock 13 inchers =) fiberglasscivic 05-21-2006, 01:47 PM Works on the front too. 01_Celica_GT 05-21-2006, 03:43 PM wow, im going to do that with the bolts. That wont mess anything up will it? I dont understand what I would need those spacers for. Where would you put those? 01_Celica_GT 05-21-2006, 03:48 PM Hey, do you think my camber could be off because the rear wheel bearing is messed up? could that make the problem of the wheel wobbling? Automotive Network, Inc., Copyright ©2012
