5 speed vs 6 speedGotian 05-16-2006, 01:41 PM I dont know if this has been discussed before, but i know this has been on my mind. As the title suggests this is about 5 speed transmissions and 6 speed transmissions. Some cars I understand why they require a 6 speed, like the 350Z or RX-8 for example. They are track cars, designed for the course which they live and breathe for. They use the 6th gear to have more room in there powerband to get up and go. They dont have enormous power like muscle cars do (which they also use 6 gears) but they have the aero dynamics to take advantage of the 6th gear. but now other cars are using a 6 speed transmission and I dont understand why. For example lets take my car, It has 180 HP with a top speed of 148 and it's a 5 speed. As far as the top speed goes, i would probably need to be in a vaccume or have alot more power to get there, cause my aerodynamics suck. But my car utilizes every inch of the 5 speed transmission and kicks itself from 0-60 in 6.3 sec. and has a 1/4 (best ive seen) of 14.8. Now the GLI (not the new one, but the same gen as my car) Has the same ammount of horsepower but is a 6 speed, and it seems to lack in performance. It's 0-60 has suffered a loss to now 6.7 and the 1/4 seems to have slowed to 15.2 (again best i've seen) and on top of that the ecu is now limited to 130 and if you take off the limiter the drag speed wouldnt be much higher than mine. Now all over the place companies are putting 6 speed transmissions in their vehicles, I just dont understand why. The SVT focus, i saw one the other day, has a 6 speed transmission and it makes me think, why? So does the new Civic SI (which was fine just as a 5 speed) The sentra SER Spec V also has a 6 speed. My train of thought when it comes to these vehicles are the following: These cars are not track oriented and are good for things like autocrossing where you only hit 3rd gear maybe once out of every 10 events, so the car stays in the peak of it's power band most of the time. They dont have an enormous ammount of power like muscle cars to need a way for the engine to relax and not waste so much gas so why have a 6th gear? Just to let you guys know this is my own opinion and I would like to hear your opinions or explainations cause to me it doesnt make much sense. So thanks and I await your responses. -Jayson- 05-16-2006, 01:52 PM well the SVT Focus was made as a track/autocross car, thats why it got a 6 speed. 6 speed for one reason, its the new car feature. No one really needs a 6 speed, but people like to say they have a 6 speed. But you forgot 6 and 7 speed automatics. I dont see a problem with them at all. Mainly because they do improve gas mileage and you dont have to shift them so you cant slow the car down by adding more gears to shift, it just goes faster. Gotian 05-16-2006, 02:02 PM well the SVT Focus was made as a track/autocross car, thats why it got a 6 speed. 6 speed for one reason, its the new car feature. No one really needs a 6 speed, but people like to say they have a 6 speed. But you forgot 6 and 7 speed automatics. I dont see a problem with them at all. Mainly because they do improve gas mileage and you dont have to shift them so you cant slow the car down by adding more gears to shift, it just goes faster. a car doesnt neccessarilly get fast by adding another gear, my point on that was made when I compared my car with the same generation GLI. And they dont neccessarilly save gas either, both jettas get the same gas milage. VR43000GT 05-16-2006, 02:12 PM My earlier take on transmissions was kind of the less power you had the more gears were nessecary (most of the time). They used to have the 3 on the tree, then the four on the floor for a lot of those old muscle cars that would have just lost time if they had more gears since they had so much power and all that shifting would have just added more acceleration time. However, now you see 500hp V8 Corvettes with 6 speeds. I don't know if the first four gears are like those of the old muscle cars and #'s 5 and 6 are just cruising gears to save gas, and your timing chain and what not. mason_RsX 05-16-2006, 02:24 PM Between the Legacy and my GSR they both desperately need a 6th gear only for fuel economy reasons...The ratios between 1-5 are so close (for obvious reasons *cough* no torque until 4000rpm) that I will be on the highway doing 120km/h (74mp/h?) at 3500-4000 which for both cars is so bad for my fuel economy For both cars I would love to have a tall 6th gear so I could maintain great fuel economy on the highway, and when I want to pass I can just downshift to 5th.....but for both vehicles company cheapness came into play...Subaru didn't want to up the cost of the Legacy by putting the 6speed from the STi in, and ditto for GSR - Type R Sleepr awd 05-16-2006, 02:35 PM i agree, cars that have more torque don't need more gears, my car is beautify w/ 5 and it is responsive and drives sportily. cars like the SI, del sol SI, rsx, GTS celica NEED that extra gear b/c their power is all up top. they have very small amounts of torque so when the driver wants to get some power and acceleration out of it, he can drop 2 gears from a cruise and get the power band fairly high. I did race a spec-v and it has rated 20crank hp less and 20 less wtq, and also weighs 400lbs less. the numbers say i should have lost, but i have better gearing since i don't have to shift as often. all i all, i wouldn't mind an extra gear, but you don't need it. might just be b/c of the new 70mph speed limits different states have. gas mileage doesn't quite crack up to what it is supposed to be, so they add another gear and keep those rpms low turtlecrxsi 05-16-2006, 02:45 PM i agree, cars that have more torque don't need more gears, my car is beautify w/ 5 and it is responsive and drives sportily. cars like the SI, del sol SI, rsx, GTS celica NEED that extra gear b/c their power is all up top. they have very small amounts of torque so when the driver wants to get some power and acceleration out of it, he can drop 2 gears from a cruise and get the power band fairly high. I did race a spec-v and it has rated 20crank hp less and 20 less wtq, and also weighs 400lbs less. the numbers say i should have lost, but i have better gearing since i don't have to shift as often. all i all, i wouldn't mind an extra gear, but you don't need it. might just be b/c of the new 70mph speed limits different states have. gas mileage doesn't quite crack up to what it is supposed to be, so they add another gear and keep those rpms low I agree. The 6th gear in a lot of these high strung 4 cylinder cars seems necessary just to keep the rpms lower at speeds higher than say 80mph. I know in my 5 speed CRX Si 80mph is over 4200rpms. A 6th gear would put me comfortably at 2800-3000 rpms where I normally would be cruising in 5th at around 60mph. Make sense? But being in 5th gear at 4000 rpms requires no downshift, just hit the go pedal and hope for the best... haha. Gotian 05-16-2006, 02:53 PM The gas milage thing doesnt always add up to me, Example, I have 5 gears and I drove to ft myers which is about 200 miles form miami and I went there and back the same day. I did this on one tank of gas going about 100mph the whole way through and averaged more than 400 miles. when Im going 100 my rpms are at about 3500. so I didnt seem to waste much gas. Polygon 05-16-2006, 03:13 PM The reason for adding another gear would be for faster acceleration and higher top speed. This given that you have enough power for the top end and closer gear ratios for the better acceleration. CBFryman 05-16-2006, 03:48 PM ^^exactly. Application dependant. New 500hp 6 speed vs old 500hp 4 speed is the new one can stay in its power band better and has the areodynamics ofr a higher top speed. Gotian 05-16-2006, 05:22 PM ^^exactly. Application dependant. New 500hp 6 speed vs old 500hp 4 speed is the new one can stay in its power band better and has the areodynamics ofr a higher top speed. okay but i was referrign to cars with smaller ammounts of power, within the 200 range, like my car, the faster acceleration is not entirely true as in the case of my car and the civic SI. Like you said you have to have the closer gear ratio's but if you indeed do have the closer gear rations than that will limit your top speed to a lower amount, say from being 140 with wider gears on a 5 speed to 130 with a 6 speed but with closer gears. Polygon 05-16-2006, 05:52 PM I see your point, and you're right. For cars with low horsepower it is more about marketing than performance. CBFryman 05-16-2006, 06:07 PM slower acceleration is due to more shifts :) 2000LS1Z28 05-16-2006, 06:08 PM 6 gears is typically for a higher gear ratio. You can have very tightly spaced gearing, and also give the enthusiast better fuel economy. Heck some of the old manual transmissions were 3 speeds. Also I believe the new Jetta is heavier then the old one, so that could account for the slower numbers generated. Heck some of the old GTI's had close to your car's performance numbers despite lacking your car's power, just because they were soo light. VW's been porking up their cars. I can't believe how heavy the R32 was. Cushy ride though. -The Stig- 05-16-2006, 09:25 PM Most six-speed transmissions, the 6th gear is a very tall Over drive gear. Like in the LS1 Fbody's and Vette's the T56 six-speed, they use 5th gear for top end runs and 6th gear for cruising. It's a bit too tall of a gear for 'racing'... mainly just an economy gear. I liked having the six-speed in the Z28, of course it had gobs of down low torque so you could just idle around in just about any gear around town. T56 1st: 2.66 2nd: 1.78 3rd: 1.30 4th: 1.00 5th: 0.74 6th: 0.50 As you can see, 4th gear is 1:1 (drive), 5th is 25% lower and 6th gear is a 50% lower ratio. A pretty steep drop in gearing... if it was ment for 'racing' use, it'd be roughly .65 or 35% less. If you look at the 6th gear ratio of most of the cars you mentioned, you might notice this trend, that it's strictly for highway use to help meet ever stricter milege requirements. Hell, everybody knows that the only way the LS1/LS6/LS2/LS7 manual cars can get past the gas guzzler tax is to have in the CAGS (Computer Aided Gear Select) where if you're under half throttle in 1st gear you get forced to go directly into 4th gear. Such a pain in the ass, luckily my Z28 had the CAGS eliminator already installed when I bought it. Gotian 05-17-2006, 01:53 AM thanks for the replies guys, answered a few of my questions, but as for 2000ls1 i was talking about the same generation jetta, mine(5 speed) and the GLI(6speed) The 1.8t were 5 speed and the GLI's were 6 Right_LiRrr 05-17-2006, 08:34 AM Dude, from my understanding it REALLY depends on the purpose of the car whether it has 5 speeds or 6. For example, my WRX I cruise at 110km/h at about 3400rpm in 5th (top gear). I used to think, damn wish I had an extra gear to save some fuel at those speeds..hmm the STi has a 6 speed. Was I right? nope! The STi at 110km/h is roughly at the same rpm in 6th gear, hence also using a lot of gas. The STi uses the 6th gear to push the rest of them closer together so you can stay in the power band for longer. Whilst many other cars use the 6th so you can cruise to higher speeds or to save fuel. Remember, the absolute ideal transmission in a car is one that can keep your car at the exact right rpm at ANY speed. The more gears a car has, the better it is able to achieve this level of perfection. Of course the trade off is having to change gears too often which slows u down and is annoying. I don't know how advanced continuous variable transmissions are nowadays, but they are designed with the beforementioned theory in mind (I may be wrong). But, as said by someone else, it is a bit of a marketing gimmic nowadays where 6 speed = sporty. But imo, any car that doesn't have a very broad powerband can benefit from close gearing. And the only way to compensate for loss of high speed in such a case is to add another gear at the end. I don't think you can just look at a car and think, oh it shouldn't have 6 gears. I really think you need to drive it and feel the gears out to feel if every gear is useful or not. Bio}{azard 05-17-2006, 05:09 PM I heard granny gears are useful Mr. Luos 05-17-2006, 05:27 PM 2000LS1Z28 05-17-2006, 05:49 PM Yeah, I can vouch for the 4.10's being nice, especially when getting out of the hole. 2.2 Straight six 05-18-2006, 04:57 PM it's hard to say. last year in WRC peugeot tested a 5-speed as opposed to a 6-speed. and found they gained time on the other cars by having less gear changes, it does, however, make a loss in acceleration-top speed ratio, in that a 6-speed will give you the same top speed with a difference in acceleration due to shorter gearings. a lot is up to personal prefrence. Mr. Luos 05-18-2006, 06:25 PM My 6th gear will NOT have a higher top speed than my 5th gear. Unless I actually had enough power to pull through it. You guys are talking high speed runs. I am talking 1/4 mile. In which case...only the gearing matters, not the number of gears. CBFryman 05-18-2006, 07:13 PM Mr Lous you cruise at 100 at the same RPM i cruise at 65. Of course i do have 4.10's :) mason_RsX 05-19-2006, 10:46 AM Dude, from my understanding it REALLY depends on the purpose of the car whether it has 5 speeds or 6. For example, my WRX I cruise at 110km/h at about 3400rpm in 5th (top gear). I used to think, damn wish I had an extra gear to save some fuel at those speeds..hmm the STi has a 6 speed. Was I right? nope! The STi at 110km/h is roughly at the same rpm in 6th gear, hence also using a lot of gas. The STi uses the 6th gear to push the rest of them closer together so you can stay in the power band for longer. Whilst many other cars use the 6th so you can cruise to higher speeds or to save fuel. Remember, the absolute ideal transmission in a car is one that can keep your car at the exact right rpm at ANY speed. The more gears a car has, the better it is able to achieve this level of perfection. Of course the trade off is having to change gears too often which slows u down and is annoying. I don't know how advanced continuous variable transmissions are nowadays, but they are designed with the beforementioned theory in mind (I may be wrong). But, as said by someone else, it is a bit of a marketing gimmic nowadays where 6 speed = sporty. But imo, any car that doesn't have a very broad powerband can benefit from close gearing. And the only way to compensate for loss of high speed in such a case is to add another gear at the end. I don't think you can just look at a car and think, oh it shouldn't have 6 gears. I really think you need to drive it and feel the gears out to feel if every gear is useful or not. I was actually bitching to my STi buddy about how the lack of a 6th gear and thats basically what he told me...In 6th on the highway hes at about the same RPM as I am...The only difference is that his ratio's are much closer to stay in that nice powerband well I said screw the powerband, all I want is 1 gear so that I can save fuel on the highway! 95_EG8_VTi 05-19-2006, 11:20 AM I Believe cars with less than 200hp do not need a 6th gear, they could just have short 1st, 2nd, 3rd and 4th gears and a larger 5th for cruising. The thing is, companies offer 6 speed trans to add a feature to a car so it is more attractive for buyers. Six speed transmissions are associated to high performance cars, and most of the economic sports car buyers do not know shit about cars, so they can be influenced by these kind of things. drftk1d 05-20-2006, 05:04 AM i dont know if it has been mentioned, but some 6 speeds work as 5 speeds with the last gear being overdriven for economy Mr. Luos 05-20-2006, 09:56 AM Both my 5th and 6th gears are overdrive. Shouldn't use either racing. At least the 1/4. If you have enough power to bounce off the rev limiter crossing the traps in the 1/4 in 4th gear....you need new lower gears. 2.2 Straight six 05-20-2006, 03:58 PM overdrive doesn't really exist in europe anymore. the golf only has 3 gears (auto) but it's limited to 155mph and there's no overdrive gear. Automotive Network, Inc., Copyright ©2012
