Going from no fog lights to having fog lightsspacey 05-13-2006, 01:08 PM My tribute has room to put fog lights in, but right now its those pretty plastic caps in there place. What would you suggest on how I go about getting these installed? Has anyone ever installed fog lights before, if so how much does it cost...or whats the average cost through a garage? Thanks!!! Stacey AlohaBra 05-14-2006, 06:42 PM I wrote about replacing the OEM factory fog lights a couple of posts back, it is still there. You might check to see if the harness connectors are there first, mine is an ES model that came with fog lamps. YOu can use an after market kit if you don't have relays and switches. I have done fog light installs before, but I was a professional auto tech. I saw a kit at Kragen's for $100 with a switch and a relay and harness as well as brackets. Make sure you fuse it also. Or you could use the low beams to trigger the fog light relay and leave the power switch under the hood. Otherwise you will have to run the switch into the dash area. Automotive Network, Inc., Copyright ©2012
