high RPM's problemsilverado4X4 05-10-2006, 09:46 PM I have a similar problem as Terradyne Kappa. After the engine gets warm, the RPM's run up to 1500 in idle. After I shut it off and start it up, it goes back to normal until i hit the gas. I am help less silverado122775 05-11-2006, 10:41 AM Don't know the year ofyour truck, but here are some common problems with High idle Throttle body is coated with carbon deposits Maladjusted throttle stop Vacuum leak(s) Speed/Distance Sensor failure MAP Sensor failure Throttle Position Sensor failure silverado4X4 05-11-2006, 11:20 AM it is year 2000, 5.3L. Mileage 135 000. I took it to a shop today and I am waiting for their phone call. silverado122775 05-11-2006, 11:58 AM Let us know what they say silverado4X4 05-11-2006, 06:43 PM They called me from the shop that everything is just fine. I told them it happens only after the engine warms up. He said they didn't run it for long, .... I guess they were busy to drive it for a while. But we have an agreement that tomorrow I will bring it straight to the shop when it's acting up. I'll keep you posted. 2000CAYukon 05-11-2006, 07:04 PM Engine Coolant Temp sensor can also cause this. Make sure they check what temp it is reporting to the PCM. Colder engine needs more fuel. //2000CAYukon silverado4X4 05-13-2006, 09:56 PM Very strange !! All of a sudden the truck runs fine. In the shop they said they didn't do anything to it. I didn't do anything to it. The only change is the weather. It has raining like crazy and the truck runs fine. Could the rain have anything to do with it ? I guess I will find out when it clears up and truck dries out. Automotive Network, Inc., Copyright ©2012
