2002 ram wont idleabaird 05-10-2006, 07:26 PM My dad called me tonight asking about a truck he repossed a month or so ago. It ran fine when the weather was cold but now won't idle. He was asking about the K&N air filter and how to clean it(he said it was caked in oil) I told him not to reoil it because that oil screws up the mass airflow sensor which is what I am assuming the problem is. However he can't seem to find the MAF. The truck is 150 miles away so I can't help him, I told him they have to be between the air filter and the throttle body but I am not familiar with this particular truck. It is the 5.9L. Any help is appreciated. sneakybert 05-11-2006, 12:51 AM A 2002 ram does not use a mass airflow sensor . I would start with cleaning the oil out of the throttle body and replacing the air filter . edbrycem 05-11-2006, 12:49 PM i was looking at putting a k&n on my 98 ram w/ 360, if u cant oil it then how can the filter work? or is it not a good idea to put one on? abaird 05-14-2006, 09:19 AM i was looking at putting a k&n on my 98 ram w/ 360, if u cant oil it then how can the filter work? or is it not a good idea to put one on? Thanks for the replies. If you oil them, don't over oil it and you will be alright. I would get an airaid or AEM intake they use dry filters that you can wash with soap and water and are cheaper than K&N. With the 02 Ram I was talking about I was assuming he had tried to run the truck without the air filter on to rule that out but apperantly not because once it was cleaned it ran ok. edbrycem 05-14-2006, 04:45 PM Thanks for the replies. If you oil them, don't over oil it and you will be alright. I would get an airaid or AEM intake they use dry filters that you can wash with soap and water and are cheaper than K&N. With the 02 Ram I was talking about I was assuming he had tried to run the truck without the air filter on to rule that out but apperantly not because once it was cleaned it ran ok. would i get one from an auto store or do i need to order one from somewhere? Automotive Network, Inc., Copyright ©2012
