Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 05-10-2006, 02:43 PM   #1
kool7
kool7 Normal reputation
Question HELP ! Where is the fuel filter ? 99 tacoma v6 2WD
Help please , where is the fuel filter on my 1999 , V6, 2WD truck ?
thanks all JOE in LAS VEGAS , NV
kool7 is offline   Reply With Quote
Old 05-11-2006, 06:33 AM   #2
gator2764
gator2764 Normal reputation
Re: HELP ! Where is the fuel filter ? 99 tacoma v6 2WD
Left side frame rail, approximately below the driver's seat
1. BEFORE WORKING ON FUEL SYSTEM, DISCONNECT NEGATIVE (-) TERMINAL CABLE FROM THE BATTERY
HINT: Any diagnostic trouble code retained by the computer will be erased when the negative (-) terminal cable is removed from the battery. Therefore, if necessary, read the diagnosis before removing the negative (-) terminal cable from the battery.
2. DO NOT SMOKE OR WORK NEAR AN OPEN FLAME WHEN WORKING ON THE FUEL SYSTEM
KEEP GASOLINE AWAY FROM RUBBER OR LEATHER PARTS
4. FUEL SYSTEM
When disconnecting the high fuel pressure line, a large amount of gasoline will spill out, so observe the following procedures:
Disconnect the fuel pump connector.
Start the engine. After the engine has stopped on its own, turn the ignition switch to OFF .
Put a container under the connection.
Slowly loosen the connection.
Disconnect the connection.
Plug the connection with a rubber plug.
When connecting the union bolt on the high pressure pipe union, observe the following procedures:
Always use 2 new gaskets.
Tighten the union bolt by hand.
Tighten the union bolt to the specified torque. Torque: 34.3 Nm (350 kg.cm, 25 ft.lb)
When connecting the flare nut on the high pressure pipe union, observe the following procedures:
Apply a light coat of engine oil to the flare nut, and tighten the flare nut by hand.
Using SST, tighten the flare nut to the specified torque. SST 09631-22020 Torque: 28 Nm (285 kg.cm, 21 ft.lb ) HINT: Use a torque wrench with a fulcrum length of 30 cm (11.81 in.) .
Observe the following precautions when removing and installing the injectors.
Never reuse the O-ring.
When placing a new O-ring on the injector, take care not to damage it in any way.
Coat a new O-ring with spindle oil or gasoline before installing-never use engine, gear or brake oil.
Install the injector to the delivery pipe and intake manifold as shown in the illustration.
Check that there are no fuel leaks after doing maintenance anywhere on the fuel system.
Connect a TOYOTA hand-held tester to the DLC3.
Turn the ignition switch ON and push TOYOTA hand-held tester main switch ON . NOTE: Do not start the engine.
Select the ACTIVE TEST mode on the TOYOTA hand-held tester.
Please refer to the TOYOTA hand-held tester operator's manual for further details.
If you have no TOYOTA hand-held tester, connector the positive (+) and negative (-) leads from the battery to the fuel pump connector.
Pinch the fuel return hose. The pressure in the high pressure line will rise to approx. 400 kPa (4 kg/sq.cm, 57 psi) . In this state, check to see that there are no leaks from any part of the fuel system. NOTE: Always pinch the hose. Avoid bending as it may cause the hose to crack.
Turn the ignition switch OFF .
Disconnect the TOYOTA hand-held tester from the DLC3.
gator2764 is offline   Reply With Quote
Old 06-08-2006, 03:28 PM   #3
bkydmech
bkydmech Normal reputation
Just some more info for you, it looks like the thread before offers some great info. I did this same job on my 96 tacoma 2.7L truck. I must say it was no easy task, I thought it would make the truck run better but essentially had no effect. These filters are designed to last a very long time and are not like filters of the past, I would not change one prior to 200K miles if I had to do it again, unless I knew for sure it was the problem. I was extremely difficult to get to the filter to change it on my truck. Good luck!
bkydmech is offline   Reply With Quote
Bookmarks
Google
Web AF
