compressionHPNOTIQracing 05-10-2006, 10:46 AM ok my new projcct has 12.5-1 pistons. i want to know how much i can safley deck the head to bring the comp. up as much as possible? i was thinking .035 das2123 05-10-2006, 02:32 PM ok my new projcct has 12.5-1 pistons. i want to know how much i can safley deck the head to bring the comp. up as much as possible? i was thinking .035As far as clearance you may be OK. I'd call whoever the manufacturer is of your pistons and ask them to be sure. neon_rt 05-10-2006, 05:30 PM I wouldn't do it, 12.5 is plenty. Decking the head will retard your cam timing, to recover you would need adjustable cam sprockets. You may also not be able to run the cam you want b/c of clearance issues caused by decking. Do what you want, just remember... If you give a mouse a cookie... das2123 05-10-2006, 10:28 PM to recover you would need adjustable cam sprockets.And what's wrong with that:evillol: HPNOTIQracing 05-11-2006, 08:30 AM sorry i didnt mention i have fidanza cam gears and crane 24's oh and this retarding the timing....its very minimal and can be corrected with my gears. and 12.5-1 is plenty for you....not me. maykelcj 06-07-2006, 01:41 AM Any Advice For Running 12.5:1 On 93octane? Retards Needed? I Have An Msd-dis-2 Programable, S-afc, And Many More Stuff.... maykelcj 06-07-2006, 01:51 AM sorry i didnt mention i have fidanza cam gears and crane 24's oh and this retarding the timing....its very minimal and can be corrected with my gears. and 12.5-1 is plenty for you....not me. UNLESS YOU ARE RUNNING RACE FUEL ALL THE TIME, 12.5:1 IS RIGHT ON THE LIMITS OF DETONATION. HPNOTIQracing 06-07-2006, 01:43 PM UNLESS YOU ARE RUNNING RACE FUEL ALL THE TIME, 12.5:1 IS RIGHT ON THE LIMITS OF DETONATION. INCORRECT! ms 2 is god of detonation. HPNOTIQracing 06-07-2006, 01:45 PM Do what you want, just remember... If you give a mouse a cookie... and while hes eating it ill run him over in my 13.75-1 compression first gen wnt2rd 06-07-2006, 05:05 PM What happens when you give a mouse a cookie? :confused: TEXSRT4 06-07-2006, 09:56 PM you are aware that when you have to retard your ignition so much to get away with your high compression on pump, you are hurting power. its all a compromise. maykelcj 06-08-2006, 02:08 AM you are aware that when you have to retard your ignition so much to get away with your high compression on pump, you are hurting power. its all a compromise. AGREE..... HPNOTIQracing 06-08-2006, 10:24 AM you are aware that when you have to retard your ignition so much to get away with your high compression on pump, you are hurting power. its all a compromise. yes i am aware but for the most part this is gonna be a track car so race fuel will be used at the track. when i use it on the street ill just put some 93 in it and swap programs in the ms2 on the laptop. Automotive Network, Inc., Copyright ©2012
