tranny oilgman_128 05-09-2006, 12:18 AM hey i have a 94 2.2 cavy 5spd and i was wondering what kind of tranny oil do you use? also is there a drain plug on the tranny to dump the old oil if not how do u change the oil? thanks Cheetoe00 05-10-2006, 12:36 AM if it is the Isuzu 5-speed transmission. It takes a special lube. its Gm part # 12345349. it takes 4.0 pints. the drain plug is on the left side and the check plug is on the top right. If it is the Muncie,New Venture 5 speed Transmission, it also takes the special lube gm part # 12345349. the drain plus is on the bottom and the check plug is on the top. gman_128 05-16-2006, 12:34 AM could you be more specific like what kinb of oil do i need 80 90 or like dextron2 something like that thanks Cheetoe00 05-16-2006, 08:14 AM I am pretty sure it is a dealer fluid only. Automotive Network, Inc., Copyright ©2012
