Hand Throttle for your manual tranny.
Mobycat
08-15-2001, 04:25 PM
OK, so I'm not sure if this would be considered an *interior* or *exterior* mod, I'm putting it in the drivetrain area.
I finished installing a hand throttle last night. Everything seems to work well.
http://www.maxc.org/mods/handthrottlehowto.htm
I know it's not the best instructions, but hopefully it'll serve as a guide for anyone wanting to control ALL THREE pedals at once.
kinetic
08-15-2001, 11:35 PM
Congrats on the nice work Moby. :cyclops:
Jay!
08-15-2001, 11:38 PM
Wow. :eek2: Great article.
I guess the kind of driving you guys do is a bit past the heel-toe stage, huh? :D
One note, though, Mobycat, I think the commentary in the left column gets cut off.
rhombus
08-15-2001, 11:40 PM
Looks great!
Nice work...
I was thinking about something like this for winching when you want the RPMs at 2000-2500 or so.
But for that I would need a dial or something that could be set like cruise control.
wilburburns
08-16-2001, 09:52 AM
Rhombus,
You're wanting a governor. they're used on semi trucks. They do just as you are saying.
I don't know of anyone that makes them for smaller trucks, but I haven't looked.
As a thought, you might be able to modify mobycat's hand throttle to work...All it would really need is something to hold the throttle in. Maybe a piece of wire around the lever and shifter..
Cliff
Mobycat
08-16-2001, 09:58 AM
If you wanted it strictly for that, I believe all you need is a gearshift handle instead of a brake handle. Gearshift (the right type) will hold in three or more positions. Just make sure you don't have it in gear and accidentally slip off the clutch! :D
rednec
08-16-2001, 11:14 AM
You could by an aftermarket choke control and modify it to work for that. I use to have an old Mazda p'up that had a diesel engine it with this set up.
wilburburns
08-16-2001, 12:43 PM
Could an aftermarket cruise control be modified to actually work as an RPM control box.
I've never installed one of these and really don't know exactly how they work.
Comments.......Anyone....
Cliff
Mobycat
08-16-2001, 12:47 PM
I would think it could. First thing you have to overcome is the cruise controls electronics - it won't work under 20mph (I think). It's based on speed, not RPM. If you could overide that, I would think it'd work fine. But you'd still need either a hand trigger, or have to use your regular gas pedal.
ScottG
08-16-2001, 04:06 PM
Premier Power Welder sells the device you guys are wanting. It is called a veniered throttle.
Synchro
08-16-2001, 04:45 PM
mark, the 4-runner owner in MAXC, put in an aftermarket cruise control, and he said his was RPM specific, not speed. so it would not have the 20mph limitations you are talking about. i imagine most aftermarket cruis controls are not like that, as your average person wants the speed control, not the RPM control.
Mobycat
08-16-2001, 06:43 PM
That's true. I wonder how one overcomes the RPM limiter? (assuming it won't work under certain RPM).
wilburburns
08-17-2001, 08:37 AM
I don't think that would be a problem. The RPM range should be held between 1500-2500 range for good charging while winching. Higher if winching for a long period of time.
Most Passenger cars actually cruise at that RPM range in OD. Overriding all the other safeties built in the system may be more challenging...Any brake or clutch override switches..:cool: Eliminating tham totally is simple, but wiring them to work correctly while cruising on road would take some extra thinking.
Cliff
