driving me crazy
akim
05-05-2006, 09:46 PM
ive had two different mech`s look at my 98 intrepid in the past four days and neither can tell me exactly whats wrong. one said maybe my cat converters are clogged with a $670 estimate but no guarantee to fix the problem. the other said he just doesnt know. sometimes my car will shut down when i stop at a light or something and on the highway all the gauges drop , then pick right back up like the car shut off because the check engine light chime sounds again when that happens. so i`m considering trying to get a diagnostic from the dealer.( help me obi-wan kenobi your my only hope!)
windowpane
06-05-2006, 08:57 PM
So...it shuts down and restarts itself? That's my first question because if thats the case I can only think it might be injectors/fuel pump maybe. But I can't think of any situation when a car would die then start itself up again.
IF it dies and then will start back up when you crank it, it might be the battery cables/terminals they tend to corrode and get loose, so cleaning them and retighting them might do the trick.
akim
06-06-2006, 09:26 PM
ok here it is ive changed the fuel pump on my decision , the computer on the dealers decision , and the battery on a mechanics decision . the car will still shut down sometimes and pick right back up in the same breath. im really getting lost , is the next step is to check injectors? for leaks or staying open
windowpane
06-07-2006, 07:22 PM
How about codes, did they find any when you brought it in? And what about now do you get any codes from the key turning it from off-on-off-on-off-on without cranking?
It may be a bad EGR solenoid getting stuck or being slow to open/close when at idle.
akim
06-08-2006, 02:46 PM
the only code it shows sometimes is (0172 )system too rich bank one , and yeah sometimes , it comes and goes as it pleases and when it goes away (the check engine light that is) the codes not there anymore , meineke said it was not the egr because thats what he thought and tested
dotson93
06-11-2006, 09:32 AM
Your o2 sensors can cause it to run to rich check the wires and make sure none of them have touched the exhaust and got a bare spot on the wire. As far as it shutting down mine did that and i changed the crank position sensor and that fixed the problem.
akim
06-11-2006, 04:05 PM
i have changed all 4 o2`s recently as well and the camshaft position sensor but not the crankshaft sensor , did you get a code for the crank sensor before you changed it?
