Radiator leak
Google
Web AF
RMT6668
05-05-2006, 05:31 AM
Hi,
My 1995 C220 developed a small leak from the Radiator (http://www.mercedesforum.com/m_45730/tm.htm#). I have taken a pic from top elevation.
Can any 1 advice me where the leak from?
Kind Regards
blindside.AMG
05-05-2006, 08:52 PM
From that picture it looks like it's coming from the lower radiator hose.
RMT6668
05-06-2006, 09:53 AM
Thanks
I have managed to open the plastic cover & view beneath to check the leak.
I have taken these pics, which shows there is no leak from the hose. But nearby there is a leak from the radiator. I also check the drain valve is tight & no leak.
On the pic, you can see a green drop of coolant is developing. I aslo took a pic from beneath the leak? Is this repairable using epoxy or resin sealent since it look like leaking from the side plastic overflow tank?
How many litre of coolant do I need to drain out of the tank so I can prepare a plastic container to catch the fluids?
Kind Regards
RMT6668
05-07-2006, 04:04 AM
There seem to be wet near the pulleys, near the water pump. Is this a water pump leak or its a normal discharge by the water pump due to cooling system prob (like a leaking Radiator/loss of pressure?)
Can I top up my coolant & drive to my mechanic?
Google
Web AF
