93 ranger v6 2wd has check engine light on *how2 diagnose*
Google
Web AF
brattzzzzz
05-04-2006, 04:16 PM
hi does any1 nkow how to get the codes from the check engine light
i have a 93 that has the light on
i see the service connector
do i just ground the 2 wires and watch the check engine light flash?
does any1 have the codes so i can look em up!????????
12Ounce
05-04-2006, 04:38 PM
You're pretty much on track. A small jumper is used to connect the two test leads under hood. Do a search or look in Haynes for info.
Your model is "two-digit" EEC-IV, I believe ... you may find the following helpful:
http://www.thorssell.net/hbook/2digit.html
stuzman
05-04-2006, 09:44 PM
And the procedure to read the code(s)...In this example, it shows a Mustang, but the procedure is the same since your year utilizes the EEC-IV system.
http://www.corral.net/tech/maintenance/eecivtest.html
brattzzzzz
05-06-2006, 12:34 AM
so where is the codes that i need?
brattzzzzz
05-06-2006, 12:35 AM
i have a 12volt light i can hook up to see the codes with i just need the code list of errors does any1 have the list?
12Ounce
05-06-2006, 06:00 PM
Why not read the codes first? Then you will know for sure if your system is 2 or 3 digit.
You can then find a list, or you can do a search outright ... for example (Google search) "EEC-IV code 14".
brattzzzzz
05-11-2006, 05:12 PM
i see a service connection under the drivers side dash?
is that the correct one or is it under the hood
if under the hood where is it i can see it!
brattzzzzz
05-11-2006, 05:28 PM
well actually
i see a TEST EEC service connector attached to the side of the fuse box but it has 4 pins
i dont know which ones to ground and how does it indicate codes
i have a test light a buzzer with 2 wires to test with but i dont know which ones to use
if any1 knows let me know
12Ounce
05-11-2006, 05:55 PM
Do you have access to a Haynes manual ?... for any Ford vehicle in the late eighties - early nineties will do.
You will find a drawing showing where to connect the jumper. Since you have a light in the instrument cluster, you can ignor all the info concerning the volt-meter ... as you will be reading the code on the "CEL" lamp.
The jumper goes between a test point on the connector you have already found ... and a single connector that is nearby on a separate lead.
OOps, just a moment ... I remember the EEC connector having 6 receptacles. I could be wrong.
stuzman
05-11-2006, 06:15 PM
well actually
Why not use the link that I posted which shows how the connections are made?
12Ounce
05-11-2006, 09:52 PM
I agree with Stuzman. The link he provided is easier to understand than the one I provided ... but both have test information provided. It takes a bit of reading.
Google
Web AF
