Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mercedes-Benz > C-Class
Old 05-03-2006, 02:23 PM   #1
mantsek
mantsek Normal reputation
Send a message via Yahoo to mantsek
Unhappy 2002 C240 won't start, transmission locked
My '02 C240 wont' start and I can't move the transmission/gear either. It is stuck in neutral. Any idea what causing this and how I can fix it? Is there some disabling mechanism on the car that I might have activated? I'm thinking it is an electrical problem but don't know how to resolve it. Any suggestions will be greatly appreciated!!
mantsek is offline   Reply With Quote
Old 05-25-2006, 02:47 AM   #2
royobi8
royobi8 Normal reputation
Re: 2002 C240 won't start, transmission locked
This shit happens when the sensor sensed you've some lugs not screwed correctly. Example would be using the original lugs on spare tire.
Check that.
royobi8 is offline   Reply With Quote
Old 09-23-2006, 12:01 PM   #3
arlingtoncountyred
arlingtoncountyred Normal reputation
Most likely the gear shifter assembly has crapped out on you, common problem. Also the EIS (electronic ignition switch) could be defective. You can not repair these items yourself, they require programming by your MB retailer.
arlingtoncountyred is offline   Reply With Quote
Old 09-28-2006, 10:25 PM   #4
99avenger2.5
99avenger2.5 Normal reputation
can you turn the key? if so does it crank or just click?
99avenger2.5 is offline   Reply With Quote
Old 11-18-2006, 05:54 PM   #5
MichaelC230
MichaelC230 Normal reputation
Thumbs down Re: 2002 C240 won't start, transmission locked
My aunt had this same problem on Thursday night, come to find it on her 99 C 230 kompressor with 70,000 miles on it and 30,000 left on the extended warranty the transmission needs replacing. It's a $6,000 job, and Mercedes is provding only a factory rebult transmission, yet, they won't extened the warranty at all.
This care has had its a/c repalced twice as well, and a bunch of other things on it, thank god for the warrantry.
MichaelC230 is offline   Reply With Quote
Bookmarks
Google
Web AF
