Need Help
moderndata
04-30-2006, 11:09 AM
I have a 2000 CLK430.
My car was worked on and they disconnected the battery.
My window don't work properly now.
Now when I push the Open Close bottons HALF WAY Down the windows open and close until you release them. THIS IS NORMAL
BUT
When you push the buttons ALL THE WAY down they dont work properly. They should open or close ALL OF THE WAY. Even if you release the button, the window should open or close completely.
I believe that this is a programming procedure, that has to be done.
Can anyone help
Thanks
Allan
99avenger2.5
04-30-2006, 01:09 PM
to normalize the window you have to roll the window all the way up and hold the the switch in the first position for 3 seconds. you have to do that to all the windows. make sure you do this with the doors closed. if this is a hardtop you some times have the normalize the sunroof also. that is done by holding the switch in the tilt up position for 3 seconds.
