'94 Pathfinder keyless remote instructionspervic 07-19-2002, 01:02 PM Can anyone tell me how to program a new keyless remote for a 1994 Pathfinder? unossingh 04-01-2003, 06:59 PM see if this works.... Set-up: Key out of ignition and driver's door open & unlocked & passenger's door closed and locked. Procedure: 1. Insert key in ignition and remove. 2. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 3. Close and open the driver's door. 4. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 5. Insert key in ignition and turn ignition ON and OFF... Once to add a new code. Twice to rewrite over ALL previously stored codes. Three times to confrim how many codes are stored in the ECU. 6. Remove teh key from ignition. The car will now respond back the selected mode by automatically locking and unlocking the doors... once to add a new code. twice to rewrite over all previously stored codes. one to four times (slowly) to show how many codes have been stored. If the confirm mode was selected the process is complete. Otherewise: 7. Press the transmitter switch on the key for 1 second. After the signal is received, the car will respond by automatically locking and unlocking the doors once. 8) Close & Open driver door 9) Press transmitter switch on the remote for more than 1 second unossingh 04-01-2003, 07:13 PM this might be better .... A: Every manufacturer has different means of programming for a replacement remote. The Nissan dealer has a choice of using a computer scan tool known as the Consult-II or the conventional method that you can do yourself. It's not too tough as long as you're using the correct remote. Get in the vehicle. Close and lock all doors utilizing the driver's power-door lock/unlock switch. Insert and remove the ignition key more than six times within a 10-second period (at a rate of one insertion/removal cycle per second). Don't rush the process, and be sure the key is completely withdrawn from the ignition-key cylinder each time it's removed. Turn the ignition to the ACC position and press any button on the remote one time. The hazard lights should flash twice, letting you know your mission is a success. If you were going to program more than one remote, you'd simply unlock and lock the doors once again with the driver's switch and press the one button, one time, on the second remote. The procedure is completed by turning the ignition off, unlocking with the driver's switch, and opening the driver's door. djfixxx 05-03-2003, 01:12 PM Under the drivers seat and carpet is a button, put the key in the ignition and turn it to on then pull the key back out, then you'll hear beeps push the lock button on the remote and you're done Buchanan6 02-21-2004, 06:49 PM djfixxx: You got it man!, I tried the other guy's way like 3 times, never worked. Tried your's once and that's all it took. Thanks! Bret maxman10 06-25-2004, 11:57 AM Buchanan6, djfixxx's message doesn't say what to do with the button under the carpet. What did you do with it to make the programming work? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
