I screwed up.....beav2k2 07-19-2002, 01:14 AM when I was installing my cool air intake(ractive) I cut my o2 sensor and dont' know how to fix it. I still have the box, but the hose is just sorta dangling there... what should I do??? JasonAccord98LX 07-19-2002, 01:17 AM Originally posted by beav2k2 when I was installing my cool air intake(ractive) I cut my o2 sensor and dont' know how to fix it. I still have the box, but the hose is just sorta dangling there... what should I do??? Why did you cut your O2 sensor while installing an intake?? HONDA_99 07-19-2002, 07:44 AM Originally posted by JasonAccord98LX Why did you cut your O2 sensor while installing an intake?? Yeah, i have same question, why did you do it? to solve problem you can solder wires but for insulation you have to use some High Tempature material and electrical isolation tape. other way to fix it is to buy new O2 sensor, but be ready to pay over $100. beav2k2 07-19-2002, 01:02 PM I didn't cut any wires, I cut the hose that ran into the stok intake, and now I dont' know where to run the hose. JasonAccord98LX 07-19-2002, 01:35 PM Originally posted by beav2k2 I cut my o2 sensor and dont' know how to fix it. Seems to me that you said that you cut something..... But now you say that you didnt?? Please try to explain this better and then maybe we can help you out:) strodda 07-19-2002, 03:13 PM Originally posted by beav2k2 I didn't cut any wires, I cut the hose that ran into the stok intake, and now I dont' know where to run the hose. unless im thinking of something else, your o2 sensor is connected to your exhaust manifold, and maybe one before your cat. my car is a lot older, but no hoes is connected from the intake to the headers. theres a tiny one that passes over the fuelinjection, and one more going to the crank case. but if youre talking about something else, then nm. beav2k2 07-19-2002, 03:35 PM ok, When I replaced my stock intake I removed the intake form the trottle body, and uderneath it was another extention to the intake. So I took it off and there was a small hose connected to it towards myy radiator w/ a little black box with wires running to it. I didn't cut any wires, I only cut the hose and I dont' know where to reconnect it, or if I should reconnect it. strodda 07-19-2002, 06:32 PM i had something similar. and when i put the cai in, it was missing that hole for the hose. the hose on mine went to some sort of air control valve that let air into the stock box. but seeing as how that valve would only slow the air coming in, its useless with a coldair intake. depending on where you live they might check for that during a smog. i live in CA, and when my neighbor had theirs done, they pop the hood and check. dont know for what, but im sure they'd notice a big silver pipe where one isnt normally. i posted about it before, ill see if i can find the post or pic i had. strodda 07-19-2002, 06:37 PM beav2k2 07-22-2002, 09:20 PM that's it... so do i need that or not? mgcatthew 07-24-2002, 02:53 AM so what runs inside the hose? :bandit: strodda 07-24-2002, 03:17 AM you dont need it. its a sensor that either controls how much air is let in, or the temperature of the air. it could either let in fresh(cold) air from the front, or it could close the valve and warm air for the engine would enter the intake. but whatever you take out, make sure you keep it. it might be something youre supposed to have for emissions when it comes time to get a smog. Melt 07-24-2002, 11:55 PM checking out your engine compartment and other pix, a couple of questions about your accord A) Did it used to be white? B) are your corner lenses missing? strodda 07-25-2002, 01:58 AM Originally posted by Melt checking out your engine compartment and other pix, a couple of questions about your accord A) Did it used to be white? B) are your corner lenses missing? actually yea, it was "champagne" or whatever that honda tanish color is called. i didnt have the money for them to paint all the edges. and i do have my corner lens' i just blacked out the inner bulb, since only the outer one signals anyways. heres a better pic of what it looks like. http://www.qubilent.com/~shane/images/cornerlens_01.jpg Automotive Network, Inc., Copyright ©2012
