Suggestions for '94 Manual Trans Noise
My '94 5-speed Ford Ranger truck with 109K miles on it originally belonged to my daughter. Once she got back from Iraq she gave me truck as she could not afford the gas to go back and forth to work. Anyway, the manual transmission now seems to be having a problem and I'm looking for some suggestions as I do not know very much about trucks. The manual transmission has a E97A sticker on it.
After it warms up, a scraping/rattling noise appears to be coming from the transmission when it is any gear. Goes away in neutral. It also becomes harder to put in gear, especially reverse. I check the fluid level and it's right at the filler plug, although the fluid does look a little dirty. The reservoir under the hood is at the right level.
Am I looking at major $'s transmission/clutch problems? I could change the fluid if you think that would help/fix the problem. Appreciate any suggestions. Jim C.
1993 Geo Metro - 1.0, MT, A/C - 343K Miles
