spark plugs
magnum3456
04-28-2006, 09:00 AM
A while ago, the discussion was brought up about that we should get AC Delco platinums. I have Bosche platinum 2's in mine. If I switch to The other ones, what differences will it make?
billibong
04-28-2006, 10:01 AM
This has been discussed almost to death in the forum. Try running a search on Delco Plats and you will find A LOT of info about it.
Basically, the design of the Bosch plugs - or autolite, champion, etc... - is not conducive to good engine performance. The only plugs that seem to have the correct teperature range for our trucks are the AC Delco Plats.
Again, I can not state it enough, make use of the search feature in teh forums. It saves a lot of time for you, as this has been discussed Ad Infinitum.
ZL1power69
04-28-2006, 11:18 AM
bosch plugs are known to break appart in our engines.
Ultrashock
04-28-2006, 11:24 AM
NGK spark plugs seem to work for me................
SComp23
04-28-2006, 11:33 AM
NKG makes a good plug also, I heard the Iridiums are compatable with our trucks
