Loud Noise From Right Front
Emmitt101
04-27-2006, 04:17 PM
Here's my problem. I have a 96 LT with 125k on it. Heard a howling noise this morning from the right front. I thought I had a flat but noticed no difference in feel. As I let off the gas it got louder and louder. Took the wheel off and didn't notice anything. Rotor turned freely. Could it be an axle or is it sometrhing else?
Also, I replaced rear brake shoes and wheel cylinders the other day and when I tried to bleed them I got absolutely no fluid from the cylinders. Still getting plenty from fronts but nothing from the right rear. What should I do?
muzzy1maniac
04-27-2006, 04:28 PM
The first problem sounds like a wheel bearing.
travis2822
04-28-2006, 03:30 PM
I had the problem with my left front a couple of years ago. It was the wheel bearing. I got it replace at Pep Boys for if I am not mistake arount $180
Emmitt101
04-29-2006, 08:55 AM
Thanks. That was the same idea that I had. Seems like a pretty easy fix. With it being 4WD it comes as an assembly. Doesn't look too hard. Auttozone has it for $112.99 and I have a relative that works there. The extra discount won't hurt. Will tackle it today.
Thanks
Emmitt101
04-29-2006, 03:26 PM
Okay. Changed the hub assembly and still makes the same noise!! What else could be the cause.
VMI07
04-29-2006, 05:23 PM
I believe I have a similar problem. Check to see if when the noise occurs and you hit the 4 wheel drive buttom does the noise stop. Mine does. I'm thinking transfer case but it could be the front axle. Let me know..
VMI07
Emmitt101
04-29-2006, 06:16 PM
My problem is this: Had a loud clicking noise coming from right front. Thought it was a wheel bearing and with it being 4WD it comes as a complete hub assembly. Not really a problem. Bought one from Autozone for $112.99, again not a big deal. Replaced the old one but stiil I have a clicking noise. The noise only happens in 2WD and not in 4WD. Transfer case or axle? Also, can I still drive it and only use 4WD? Not being very familiar with 4WD should I use 4 Hi or 4Lo? I'm thinking 4 Hi but I want to be sure. Also what more damage is capable of happening in 4WD?
Thanks,
Jeff
blazee
04-29-2006, 06:24 PM
It could be your 4wd partially engaging. Usually the result of a bad vacuum switch on the transfer case.
Emmitt101
04-30-2006, 07:51 AM
Will I cause more damage by driving in 4WD? You seem to be pretty knowledgable. What do you think?
