Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 04-27-2006, 11:38 AM   #1
bigdawg703
bigdawg703 Normal reputation
How to change PCV on 2005 3.4L?
I was going to change the PCV on my 3.4 engine and I couldnt get it out.... it looks as tho there is a plate holding it on that is rivited to the engine on both sides???? Please Help
bigdawg703 is offline   Reply With Quote
Old 04-27-2006, 01:43 PM   #2
JJ Newel
JJ Newel Normal reputation
Re: How to change PCV on 2005 3.4L?
what are you talking about, what rivets. First you pull up on the pcv valve while it's still on the hose then you twist it while trying to pull it out of the hose. But I don't think you need to replace your pcv valve already.
JJ Newel is offline   Reply With Quote
Old 04-27-2006, 02:07 PM   #3
bigdawg703
The hose comes off the top of the PCV fine, the PCV itself is stuck in the valve cover gasket in some type of rubber grommet or sumn but the problem is that on top of the PCV there is a metal clip that want allow you to pull the PCV out of the rubber grommet, the flange on the PCV will not pass through it, and this metal clip is held on to the valve cover gasket with a bolt on either side that is flat...... I went to autozone and they had never seen anything like it before.... he said I would have to drill out the rivits and replace the PCV then put some bolts in place of the rivits..... the car is a 2005 with 105,000 miles on it
Old 04-27-2006, 02:34 PM   #4
bigrod118
bigrod118's Avatar
bigrod118 Normal reputation
Send a message via AIM to bigrod118 Send a message via MSN to bigrod118 Send a message via Yahoo to bigrod118
http://www.impalahq.com/HowTo/PCV.htm
bigrod118 is offline   Reply With Quote
Old 04-27-2006, 02:49 PM   #5
bigdawg703
Yea I have already read that article.... but my pcv looks different from the pictures, maybe since mine is a 2005 it is different iono.... mine looks like that but with a metal clip holding it on, im thinking about just cutting the clip and moving it then moving it back when I replace the PCV..... hopefully this want mess anything up....
Bookmarks
Google
Web AF
