2000 se rough idledodge9fan 04-26-2006, 11:26 PM Problem just started today. We have a 2000 SE which started idling rough and dying. It will idle smooth at times but drops to about 500 rpm and surges trying to idle and die. Ran it down for a code check, and 7 codes came back. 3 said something about "too lean", 1 said something about oxygen sensor, and the others said something about throttle and pedal. Anyone have any ideas? TaurusKing 04-27-2006, 12:33 AM There's a lot of good people willing to help out here, but the exact codes are needed to begin, also mileage and engine type are always helpful. brokenantimatter 04-27-2006, 12:48 AM There's a lot of good people willing to help out here Don't tell people that, they will expecting us to give them the right answers if you do...............:iceslolan Anyways like TK said: Exact Error Codes? Mileage? Engine? Any recent work done? Any recent harsh weather or vehicle treatment? dodge9fan 04-27-2006, 11:13 AM The error codes that I can remember were P0171, P0174, P1137, P1157, P1125, and P1100 Mileage is 110216 Engine is a 3.0L V6 EFI U-code Any recent work done? none Any recent harsh weather or vehicle treatment? none yotermanic 04-27-2006, 12:05 PM Sounds like you probably have a vacuum leak. Check all the hoses, and take a good look at the main air intake hose from the aircleaner. If this comes unseated, the car will barely run and may stall when loaded. Another common leak source on all Fords are the PCV hoses, which seem to rot as quick as you can replace them on some cars. Anyhow, there's my two pesos, good luck with it and let us know what turns up. dodge9fan 05-08-2006, 02:48 AM votermanic. it was indeed a vacuum hose to the pcv valve. thanks, Automotive Network, Inc., Copyright ©2012
