2002 tuarus idles rough
rednex24
04-26-2006, 06:08 PM
My 2002 tuarus sel idles rough when idling,whether its parked or in gear. I can hear a vacuum leak but cannot locate it
brokenantimatter
04-26-2006, 09:39 PM
I leak that makes a squeal or a screech?
Have you recently had ignition problems or smoke from under the hood? We have seen this problem pop-up in about 10 different DOHC Taurii in the past two months. (60-80k mile region). I am not sure what the specific hose is but it is located below the throttle body and has a tee connector. On all of them but 2 it was the top hose.
rednex24
04-26-2006, 09:54 PM
There is no smoke or squeal at all,just the sound of sucking air when it is idle or in gear at a stop.It has a bit of a chug when sitting at a stop with the car in gear.
brokenantimatter
04-26-2006, 10:09 PM
Hmmm?
Check the air intake for holes or lose hoses.
rednex24
04-26-2006, 10:16 PM
Have already checked that!! It seems to be somewhere at the back end of the engine.
yotermanic
04-26-2006, 10:41 PM
Be sure to check the hoses on the PCV system, they're always bad about rotting through.
brokenantimatter
04-26-2006, 11:19 PM
Check the air intake hoses below the throttle body....the ones that look like they would going toward the tranny or the actual engine block.
