2002 toyota tacoma Altezza Tail light problemtriniperformance 04-26-2006, 02:11 PM I just bought the Altezza tail light with the Harness for a 02 tacoma but when I installed it, the problem that I am having is the the right indicator light is constantly on, on the right side of the truck. Anyone has a suggestion, I replace the harness with the company that i bought it from but it seems that is not the problem. triniperformance 04-27-2006, 08:05 AM I just bought the Altezza tail light with the Harness for a 02 tacoma but when I installed it, the problem that I am having is the the right indicator light is constantly on, on the right side of the truck. Anyone has a suggestion, I replace the harness with the company that i bought it from but it seems that is not the problem. Just for everyone to know that I found the solution, you need to checl the right tail light connection as the ground wire is not the same as the harness that comes with the altezza lights as it is being joined to the current line instead of the ground line on the new harness, you do not need to cut any wires from the truck. Flash75 04-27-2006, 12:00 PM Thanks for posting the solution. Clifton vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
