B20b
golf-2
04-25-2006, 05:06 PM
Hi
i got a b20b engine from a cr-v 97
i plan to convert it to turbo and put it in my 92 civic si
i heared that this engine is 8.8:1 compression piston
ok any ideas for this and is the internal can't explode when
i throw about 15 psi of boost?
somthing else which flow rate and the impedence of the
injectors i need to the 15 psi?
thnx
kris
04-25-2006, 08:59 PM
I would not boost 15 pounds on any stock motor.
Rgacke
04-26-2006, 12:12 PM
I'm a little curious why you want to run 15lbs but haven't mentioned any HP or 1/4 mile goals.
b20s tend to have the reputation of weak cylinder walls. From what I've read b20s have 6mm seperating each cylinder VS. 9mm in all the other b series. Some people have had consistant problems w/the sleeves cracking and others haven't. The peole who haven't are not running 15lbs though.
golf-2
04-26-2006, 05:16 PM
ok right
the goals is 13 or 14 1/4
i heared about the thin of the sleeves about this engine
ok before i start this project
any idea about better b series?
is the b18b ran safty with stock internals?
can i lower the compression with another b series rods
or pistons
the stock parts are not problem to me
but i want to put somthing not to explode by 2 or 3 boosting
thnx
