Leaky Differential
PeteCal
04-24-2006, 09:08 PM
The differential of my '98 Trooper is leaking fluid from the area of the front seal.
I understand it could be a plugged breather and I will check that but, given my luck, I may need to replace the seal.
The shop manual says I need a J-8614-01 special tool to remove the flange nut and a J-37263 Seal Installer to install the seal.
It then says, to "Adjust pinion preload:
a. Measure the bearing preload by using a torque meter (?) and note the scale reading required to rotate the flange.
b. Continue tightening the flange bolt until the specified starting torque is obtained. STARTING TORQUE 1.1-1.6 N-m
NOTE Pinion torque should be in the range of 298-380 N-m."
Question #1, Can I do it without the Flange nut tool?
Question #2, Can I do it without the Seal Installer?
Question #3, What do these torque readings mean? I believe step "a" means find out how much torque it takes to start turning the differential then somehow keep it from turning and add 1.1-1.6 N-m more torque. But if the pinion torque should be in the range of 298-380 N-m, how the he** can you measure 1.1 on top of 280. I must be missing something.
Any ideas?
Are these the only problems I am facing?
Any idea how much the dealer wants for a new seal or is there a better source?
Thanks in Advance
Pete
marcre
04-24-2006, 10:57 PM
you may have more luck asking this on the wire. I believe the preloads are serious business and it is best to make sure they are correct. I think I read that on the wire when someone asked a similar question.
marc
PeteCal
04-24-2006, 11:02 PM
What do you mean by "on the wire"?
marcre
04-24-2006, 11:06 PM
the wire is a site like this.
www.4x4wire.com.
There is a lot more traffic there that would be better suited to answer this question. Those guys have more experience with this type of thing. It is also a good place to ask questions.
marc
