Small shake when accelerating
joeuser742
04-24-2006, 12:10 PM
I was wondering if anyone had a suggestion what this could be. My truck has a small shake when I accelerate when stopped. It only happens at inital take off, but once I'm moving, it doesn't happen. I just put new motor mounts and trans mount on. Could it be that I need to adjust the mounts a certain way or maybe something else?
JoshBarber
04-24-2006, 12:13 PM
if it has just started SINCE doing these mounts, I'd look to them first for sure.
if it was prior to the mounts, How's your alignment? Tire-wear? Etc?
BlazerBoyLT98
04-24-2006, 12:33 PM
Could be the u joints on the drive shaft are going, i would only feel a shimmy at low speeds, once going along over like 10 it would go away. Check that out. Good luck
joeuser742
04-24-2006, 12:58 PM
The shake was there before the new mounts, but now it is much more noticeable. One mount was ripped and maybe that's why I didn't feel it as much before. New tires, alignment, brakes....and everything else. I've actually had something similar happen with another truck I had, and it was the trans mount. Right now I'm leaning towards ujoints.
I'd like to add that it feels like the shake/shimmy is in the front and it's not in 4wd.
the87hyper
04-24-2006, 01:02 PM
Yup more then likely the u-joints. Mine did the same thing. Just replace them there rather in-expensive and dont take but a hr to do. Good luck
BlazerBoyLT98
04-24-2006, 01:04 PM
I had a Jeep CJ7 that ate ujoints like they were going out of style
joeuser742
04-24-2006, 02:05 PM
Thanks for all the replys, I'm going to replace the ujoints and go from there.
BlazerBoyLT98
04-24-2006, 05:45 PM
hey it's worth it, cheap replacement
