Hi all
mrgrim
04-24-2006, 06:03 AM
I just picked up an 03 LS with every option.This thing has been a challange to say the least.I do like the car and I am hopeful I can fix the issues and enjoy the car.
So far I have had the throttle stick and just about get me killed.After remove and clean of throttle body,new TPS,new cables it turned out to be a defective pedal asm.The pedals are stocked at all my local dealers so it must be an issue of some kind and it only cost $40
Over heating was a stuck thermostat not to bad to fix.Flushed the system while I was in there as well.
Door locks inop was just a fray wire under dash a pain to find but easy fix.
I am left with 2 issues
Trunk is leaking water and the radio says LOC,I did try the hold 1 and 4 buttons but it never shows any number.On my radio you cant hold 2 and 3
so I guess the radio is toast.The truck seal I replaced so it must need the latch adjusted.
Any input for my last 2 issues?I would be glad for any help.
e2helper
04-24-2006, 06:49 AM
LOC is displayed when the VIN expected by the radio isn't what is being transmitted by other modules in vehicle. Is it possible you have a radio from another vehicle installed? I think only a dealer can fix that because they would have to force the radio to relearn a new VIN.
Do you have owner manual for vehicle?
https://www.mygmlink.com/pdf/go2content/manual/US/en/chevrolet/2003malibu.pdf
jonnik
04-29-2006, 07:41 AM
A friend of mine with an '02 had a bad tail light gasket leaking water in the trunk-might check that.
bcopeland
05-03-2006, 08:43 AM
Not in my Malibu, but my Yukon XL gives me a LOC about once every 3 months.
mrgrim
05-10-2006, 05:57 PM
Well the throttle sticking turns out to be the pedal asm its self.New gas and brake pedal unit was instock at local dealer they had 9 of them.Radio was locked due to the vin not matching.It was a junk yard unit so I just put in an after market cd with sirius.Have not gotten to the water leak yet.
