fuse of fuel pump brake offrricardo70 04-23-2006, 10:23 AM The fuse of fuel pump is getting brake off very often. I change already the fuel pump relay. Thank you a lot, Ruben Ricardo shorod 04-23-2006, 12:32 PM As a general rule of thumb, please post the year, engine, and body (sedan or wagon) of your vehicle when requesting help. Knowing the model year and engine in your car may help determine what else should be on the same circuit as your fuel pump. Just because the fuse is labeled "Fuel pump" does not mean that is all that is on that circuit. You may want to start by unplugging the fuel pump and see if the fuel pump fuse still blows. You can do this at the fuel pump inertia switch. Also, does the fuse blow as soon as you turn the key to "Run" or does it blow when you after you turn something on, etc. The more details you can provide, the better chance we will have of narrowing down the possible problems. -Rod Automotive Network, Inc., Copyright ©2012
