| Performance Discussion about performance modifications and issues. |
04-23-2006, 06:13 AM
RB26DETT is restricted?
I once read on a website about GTR that the RB26DETT has this thing called a "govenor" which is like a small computer thing that restricts the engine from producing max power. It sed if u take this off the RB can go up to 450hp. is it true?
04-30-2006, 09:05 AM
Re: RB26DETT is restricted?
no if that were true everyone would be running around with 450hp skylines,
but it is resticted some what and power is easier to acheive than other cars.
05-02-2006, 06:11 PM
probably, most cars have one so they can keep reliable and maybe to pass emissions......i wouldn't reccomend taking it off (can't remember why but i think it keeps your car from going faster than your crank or something)....you can just get a chip that adds a couple of hp and will bypass the governor + you can't go up to 450 without a governor since you can't unleash hp that wasn't hidden in the first place
07-21-2006, 04:34 PM
ur prolly thinking of the Gentelmens agreamnet that was set in Japan up until a couple years ago. it stated that all auto makets were to produce no more than 280ps out of there cars. now rumor had it that the GTR only claimed to abide by this agreement, but in reality they pushed more power from them (which is another reason y they are so highly thought of, cause everyone else stuck to the 280ps limit hehehe)
07-23-2006, 02:29 AM
Nothing governs the power! Top speed yes, but not power. Unless you consider the exhaust, stock boost, and intake do limit the engine. But, those are an easy fix, like what was metioned, need a chip to get rid of the speed limter, but if your going to upgrade the exhaust, intake, and run a boost controller, you're going to need to map it.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
09-17-2006, 02:04 AM
Hi flow air filters, a 3" exhaust from the turbos back and raise the boost to 13psi should see around 400Hp@wheels... Nothing restricted about that
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
