What type of Digital Multimeter?lottathought 04-22-2006, 05:14 AM I am not a total noob under the hood but I am starting to get heavier into repair and I am looking to put the proper tools into my garage. Currently, I am on the hunt for a Digital Multimeter. I have seen the comments on Fluke. It is obviously a very good machine. It is also a very costly machine. I can not believe that only Fluke makes a good meter and all the others on the market are junk. Even if I did, Fluke also seems to have a wide range of products. So here is what I want to know. What other names and models of Digital Multimeters would you reccomend? What features am I going to be using? Although this is mainly going to be used on the autos, it will probably not be limited to that. (1995 BMW318is, 2000 Mustang, 1999 Explorer) I do not want something that will be out of date tommorow. I also do not want to waste a lot of money on bells and whistles that I will never use. Also, what is an acceptable variance in a machine's readings? lottathought 04-22-2006, 07:23 PM Aw cmon guys. I am sure that somebody has thoughts about this. Bear 04-22-2006, 07:49 PM I bought mine from Radio Shack about five years ago. Works well on my 1988 750 and around the house as well. Antiburn 04-22-2006, 08:53 PM If your local sears store sell craftsman tools they make a comparable meter to the fluke. All you need in a meter is to read, volts, ohms, amps and resistance. Anything that requires more is sually to hi-tech for a back yard mechanic like yourself to be performing, IE: draw tests and whats the millie volts (however its spelled) of your airbag moduel. Like i said, get a meter that can read, ohms, voltage and resistance and your be set. lottathought 04-30-2006, 03:53 AM I picked up a Craftsman multimeter. I do not know if they are rebadged Fluke meters or not. When I opened the manual however, their was a yellow card stating that it had been calibrated by Fluke. Automotive Network, Inc., Copyright ©2012
