running day light out
redscorpio69
04-22-2006, 12:58 AM
my 2000 malibu do not turn the day lights on automatic
i have to turn them on by the swich ... anyone knows why? any help
redscorpio69
04-24-2006, 09:41 PM
does any one can tell me where is the fuse of the day running ligths mine are not turning on by themselfs
e2helper
04-24-2006, 10:15 PM
If you are really talking about Daytime Running Lamps I am curious if you are not the original owner of the vehicle are you sure they worked at one time or not?
There seem to be many people out there who dislike DRLs so much they figure out ways to disable them.
Anyways to answer your question....there is a DRL relay (#22) in the underhood electrical center of your vehicle and its coil is fed by the HTR A/C IGN fuse (#46), which also feeds many other things so that fuse is likely OK.
The DRL relay actually switches the low beam headlamps to ground through a power resistor so there isn't any special fuse, they use the same left and right headlamp fuses (#50, #51) for the power for DRL mode of headlamps.
