97 Taurus P 0455
HansonHVAC
04-20-2006, 07:46 PM
Hey my parents have a 97 Ford taurus and the engine light came on today. I threw my code reader on it and it threw P 455. I looked up this code under a search engine and it came up insufficient RPM increase. Is this correct? If so any ideas what could cause it and how to fix it? Thanks
way2old
04-20-2006, 08:32 PM
Continuous Memory Diagnostic Trouble Code (DTC) P0455 indicates that the Evaporative Emission (EVAP) control system detected a large leak or no purge flow.
Possible causes:
After market parts and accessories nonconforming to the EVAP system specifications.
Damaged, missing or improperly installed fuel filler cap.
Blockage in fuel vapor hoses/tubes (EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube) in EVAP system.
Disconnected or cracked fuel vapor hoses/tubes in EVAP system.
EVAP canister purge valve stuck closed.
Canister vent (CV) solenoid stuck open.
Fuel tank pressure (FTP) sensor malfunction.
EVAP canister leaking.
Fuel vapor control valve tube assembly blocked.
Fuel vapor vent valve assembly blocked.
Check for missing fuel filler cap. If the cap is loose DO NOT DISTURB EVAP system.
Verify that both the input port vacuum hose and EVAP return tube are attached to the EVAP canister purge valve.
Note: If the EVAP canister-CV solenoid assembly is not accessible to perform the following step, Go to the Powertrain/Engine Group, Evaporative Emissions Section in the Workshop Manual for removal and installation procedures.
Verify that the CV solenoid is properly seated on the EVAP canister (if possible).
Visually inspect for disconnected or cracked fuel vapor hoses/tubes between the intake manifold, the EVAP canister purge valve, the EVAP canister, the fuel vapor vent valve assembly and if applicable the fuel vapor control valve tube assembly.
Check for damage to the fuel filler pipe and the fuel tank.
newton_21989
04-23-2006, 01:27 AM
My parents had the check engine light come on on their '01 Explorer one time when, I guess, they didn't have the fuel cap on tight. Might want to try giving that another crank.
