gages down
specialist
04-19-2006, 05:32 PM
i have a grand cherokee that troubled my for days.When i put on ignition all gages and power window working ok.When i turn engine on the gages stay on for second and then fall all to cero and the power window won't work.It is a grand cherokee 1999 with 70000 m on it.
thanks
Bob D.
04-20-2006, 02:43 AM
Check the connection of battery cables. (at the battery)
specialist
04-20-2006, 08:17 AM
Hi Bob,
I have check the battery and cables,they are ok also the charging system.Tricky is that when i let engine run for 5 or 10 minutes they all start working untill i let the car cool down again.
God bless
Bob D.
04-23-2006, 06:51 PM
Sorry, been out of town.
Well, that's an odd one. Sounds like it's temperature related from your pm message to me. Could be the BCM (Body Control Module) or a bad ground somewhere.
Here is something you can try...sometimes the electronics get "buggy" and need to be reset.
Remove the negative battery cable, then turn the ignition to "START" and hold for 5 seconds.
(This will bleed off residual voltage to the electronics.)
Wait a few minutes and start it up. Check the gauges and see what happens.
Good luck.
g1smith
05-06-2006, 07:00 PM
My '99 JGC did almost the same thing, the gages would drop to zero when the engine died . . . usually on the freeway in the most inconvient of situations demanding death defying manuvers to get the thing stopped with engine off . . . thank GOD for my pilot training years ago! Darn instructor kept shutting the engine off and said . . . where ya going to land now
My JGC would die when it got hot. I cleand all grounds, changed Crank Position Sensor, Cam Position Sensor, MAP, TPS etc. etc. eventually replaced the PCM Power Control Module and it hasn't happened again . . . yet . . . it spring time againg and the wife's afraid of driving it . . . again. $500 from the stealer and $100 used from the internet plus a programming fee.
