95 Pathfinder Power Loss, Bogging Out, Bad Mileage
Over time, our 95 Pathfinder has been losing power. When accelerating it kind of wants to bog outand you really have to press the gas pedal into it. Also, on the highway, it will bog or lose power and you find yourself pushing into it with the gas pedal more and more to keep it up to speed. There are no check engine lights. It kind of feels like the brakes are being applied. It doesn't miss or die. It sounds okay, it is just losing power. Is this indicative of an O2 sensor going bad? Another theory I have is maybe the ignition module or coil is going bad resulting in a weak spark. I have purchased a new air filter, but haven't put it in yet. Will tonight. Another thought I have is that there may be some problem with the throttle body. Just not sure. The transmission is always shifting down to get it back up to speed. It seems underpowered or something.
Also, it seems to REALLY be getting bad gas mileage. Worse than before. It never has been real fuel efficient. Yesterday, it really sucked the gas. I went about 70 miles and it used around 6 gallons of gas. Fortunately, this is a spare vehicle. It used to get around 16 MPG or a little better. Seems like about 10 MPG or a little better now.
Any ideas are appreciated!
