Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 04-18-2006, 12:57 AM   #1
dk05
dk05 Normal reputation
Annoying Distributor... Argh!?
I must have tried this at least 100 times...
Set distributor in
Turn oil pump shaft
Pull distributor out...
Did not seat correctly, try again...
I even tried marking where the slot on the shaft should face. Now the funny thing is that I tried it on my old 305 sitting on the crate (the old motor from the car) and in the 1st try it seated correctly. I can't seem to get it on the 350 correctly, and I don't want to try starting it without the shaft seated in the end of the gear. One other thing I tried was setting it in then rotating the crank over 2 times. Still would not drop. The only thing I saw looking down the shaft is that there is a little tab looking thing opposite the camshaft toward the rear of the motor. This is the only thing not on the 305. Is there some difference in the 305 to the 350 preventing me from reusing my distributor that I am not aware of? Thanks.
dk05 is offline   Reply With Quote
Old 04-18-2006, 09:12 AM   #2
wrightz28
Backstabbing AF Moderator
wrightz28's Avatar
wrightz28 Normal reputation
Re: Annoying Distributor... Argh!?
Firing order is 1 8 4 3 6 5 7 2
from the fron t of the motor should look like:
.....6.....5
...3.........7..t
...4.........2..b
.....8.....1
**I might ahve the b (battery) and t (tach) feed reversed, but you get the idea.
My dist. was a PITA to reinstall aswell, don't know wht the deal was, came out easy as pie and nothing moved but it refused to line back up with the oil pump .
wrightz28 is offline   Reply With Quote
Old 04-18-2006, 12:29 PM   #3
1986Z28
Drinks Nitro
1986Z28's Avatar
1986Z28 0
Send a message via MSN to 1986Z28
ive had the same problem, i eventuallly got it after like 50 tries
-1986 Z28 - 355 carb, T5
-1986 Sport Coupe - 305TBI and T5(parts car)
-1985 Z28 - No drivetrain(getting scraped soon)
-1989 RS - 2.8, 700R4(parts car)
-1991 Z28 - 355 OBDII tpi HSR, T56(soon hopefully)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
"Id rather push my chevy that drive a ford"
"God invented shit, ford put wheels on it"
1986Z28 is offline   Reply With Quote
Bookmarks
Google
Web AF
