How Many Miles on Your Malibu?
gaspig
04-17-2006, 10:55 PM
I have a 2002 Malibu with 67,000 miles and have replaced the lower intake manifold gasket, turn signal relay and blower motor resistor twice.
ViperJ
04-18-2006, 12:16 AM
99 Malibu, all that has gone wrong is the intake manifold, I got a lucky one I guess
malibugtp
04-18-2006, 04:34 AM
01, 101xxx, intake gasket 2x's. blower rsistor., that is it. all he other "bad things" that supposedly go worng with the malibus i either havent gotten yet, or i replaced it with aftermarket performance parts
sswpriz
04-18-2006, 06:13 PM
I have a 98 with 142,000 miles. Had to replace the front wheel bearings, at about 90K, the water pump, camshaft position sensor and alternator all within the last 6000 miles. Bad things come in 3's ? I had a tune up at 97K, Oh and 1 fuel injector a while ago, but otherwise thats about it. I'm knocking on wood right now because I haven't had to do the manifold gasket yet !!
I still average 25 MPG with the 3.1
bcopeland
04-18-2006, 06:59 PM
We all know these problems well - read the threads. What is up?
tractorboy
04-19-2006, 08:44 AM
98 with 70k, replaced the lower intake 3 years ago ( may not have been the intake gasket , may ahve been the temp sender leaking), and had the factory recall campain done for the wipper motor or arm.
mazingo
08-25-2006, 11:49 PM
New to Forum, so hello to all. 2001 Malibu with 116,000 miles +/-. Has a bad fan resistor, a blinking A/C light, leaking ECT sending unit, leaking Intake gasket (I hope its just the sending unit but not likely). I plan to replace the ECT SU tomorrow and the intake gasket next weekend. I hit a deer in october of last year. Then I hit another February of this year. Other than a black hood and gray bumber tha car looks okay. Oh yeah I average about 28-30 MPG.
john20
08-26-2006, 02:33 AM
no, WE don't all know these problems... I'm still learning about how big of a junker my car is...it's good to see all these problems all in one thread.
99 with 108,000, I'll be replacing my intake gaskets tomorrow. Got a new alternator, need to replace my fan resistor, bad antenna (need to fix, but not sure what though) replaced front coil spring, cable on my passanger seat broke
I think that's it... knock on wood :uhoh:
samturner
08-26-2006, 10:22 AM
right at 200,000
replaced intake gasket at 190,000 and passlock at about 160,000 front brake pads at about 120,000 plus blower resistor.
Up to about 180,000 was only driven highway miles. Been a good car. I gave it to the wife after I took it off the road and she loves it.
bcopeland
08-26-2006, 01:37 PM
Question is - Do you have a deep freezer full of deer sausage?
samturner
08-26-2006, 02:02 PM
Nope no deer sauage and like I said the wife loves the Malibu but my car of choice now is a 1991 LS Cougar 3.8 engine. The Malibu can never compare to the ride the Cougar has but alas Ford products have a few problems. The Cougar would also never make it out of this hollow in any snow, it slips on wet grass.
When I get the 48' Chevy 2 door Fleetline finished then I will have something I can work on. Just need to find some plasti gauge to adjust the rod bearings they are still babbit
slls
08-27-2006, 11:41 AM
I had a 48 Chevy, overhauled the engine, if I remember rightly the rods are not pressure feed, it has a scupper.
porrsher
08-27-2006, 03:26 PM
2004 (new body style) LS 137,400.
Replaced electronic steering mechanism, front seat base, radio after cd got stuck and would not eject, cruise control button on steerin wheel.
Things wron with it now; left daytime running light works randomly making the turn signal rapid flashing, you have to actually reset it everytime with the ignition for it to stay on, buttons are peeling, like the trunk button and lock buttons on the door, and fuel gauge is faulty when filled up goes to empty, as fuel is comsumed it will sometimes operate again. Seat base weld broke again when a "big guy" at the stealership where I was getting an oil change sat on it with force I take it since the weld broke, again. so not the seat dips about 2 inches on the back when I sit on it so I have things to pry it up to keep my back in form.
Thats all I can think about for now....
red933
08-27-2006, 04:58 PM
120,000 on a 1982 Malibu Classic. Ah, what a cute little V6. Puttin' a new cam/lifters in her now. She was running great until she started to backfire and sputter around town. I've damn near rebuilt the engine so far, should have just pulled it out. Hey, no more jokes about rebuilding V6 engines. 350s are fun but this is an everday driver. And with gas prices they way they are............well I'm not rich.
Dalt10
08-30-2006, 08:24 PM
97,950, I had the lower intake manifold gaskets replaced at 95,000. The front struts, strut mounts need replacing now. Console arm has fell apart. Top back of seat cushion is wore out (I'm 6'2" and weigh 260 lbs). Drive around 60 to 80 miles a day. I call it my throw away car. Drive it until it falls apart and throw it away.
adgjqetuo
09-01-2006, 02:13 PM
98 Malibu Base, 75,000 miles.
Replaced 1 blinker bulb, 1 brake light bulb, Blower Resistor, and the brake caliber had to be rebuilt.
So far nothing major ::Keeps fingers crossed::
johnschmitt
09-02-2006, 12:13 AM
99 LS with 136,000 bought it in 02 with 38,000
So far I've replaced: one lug stud and one lug nut (thanks goodyear), front bearings, left cv shaft, right front quarter panel (long story), factory stereo, blower motor and resistor, parking brake idiot light switch (about to do it again), intake gaskets, water pump, alternator, battery, some light bulbs, horn (full of water), splash shield that protects the horn, a couple fuses, front brakes several times, iat sensor, wiring to iat sensor, radiator cap, tie rod ends, materials associated with 30 or so oil changes, drive belt, a few sets of tires, pcv valve, and spark plugs.
Honestly after owning a 92 topaz I think I got off easy.
smurda
09-02-2006, 03:05 PM
2000 malibu with 157000 miles. just replaced front brakes, rotors and front left caliper today....
chasM
09-06-2006, 11:17 AM
2001 Malibu with 60k. I'm the original owner.
Blower motor resistor
Front brakes at 13k- Used non ceraminic pads and non bimetal rotors- still going strong!!!
Rear wheel cylinders at 40k miles leaked.
