Re: New rims cause car to shake
I took some info from your other post.. Are these also called spacers, by another name??? They're like 5mm or so thick??? I see from your other post that it's a noticeable wobble, also causing the steer wheel to shake,, seems you have a major issue going on, was the clearance with the wheel and hub checked?? Something's probably not installed square, or bent, maybe too many spacers with stock lugs??? I'm not familiar with putting bigger then stock wheels on newer cars, 18 from 16 seems a rather large jump, imo... I thought wheel spacers were illegal, don't take that to the bank though, I've been wrong plenty, If you changed wheels and these problems cropped up, then they're the deal.
