boost controller installationhany 04-17-2006, 08:13 AM this is my one http://files.automotiveforums.com/gallery/watermark.php?file=/503/328922BC-305thumb.jpg anyone know how can i install the Gated In Cabin Boost Controller ? Polygon 04-18-2006, 05:03 PM Well, you just need to put the solenoid on the vac line before the wastegate and then run the hose through the firewall and connect it to the controller. Didn’t it come with instructions? hany 04-19-2006, 06:03 AM yes it did not come with the instruction. can you help me with diagram ? i know that it will be hard . but as you saw my signuture my english is not well. Polygon 04-19-2006, 10:55 AM Do you know what your wastegate looks like? If so find the wastegate and the vacuum line going to it. All you need to do is cut that line somewhere between the wastegate and the vacuum source then connect the two ends to the solenoid. I wouldn't be able to help much with a diagram as I don't know much about vac systems in Hondas. I come in here simply because I know a fair deal about forced induction. hany 04-19-2006, 01:00 PM i will easy the matter for you. tell me where the hose go in each no. and please what is the solenoid mean ? http://files.automotiveforums.com/gallery/watermark.php?file=/503/328922BC-305thumb1.jpg CivicSpoon 04-20-2006, 01:22 PM http://www.turbosmart.com.au/index.php?s=file_download&id=18 If that link doesn't work, click the Downloads section of the www.Turbosmart.com.au (http://www.Turbosmart.com.au) website, and click "In-Car Boost Controller [461.46kb]" hany 04-20-2006, 07:33 PM thank you very much . i read it and i understand it very good. but what does engine bay mean ? Polygon 04-21-2006, 11:27 AM thank you very much . i read it and i understand it very good. but what does engine bay mean ? The engine bay is where you engine is. hany 04-21-2006, 01:25 PM The engine bay is where you engine is. that mean all the area which under the hood is conseder engine bay ? alphalanos 04-21-2006, 01:31 PM pretty much! hany 04-21-2006, 05:45 PM in the installation it say : (Exhaust hose - to engine bay) that mean i take the hose to any area under the hood and put it.then it will exhaust to the atmospher under the hood ? ? superbluecivicsi 04-23-2006, 09:33 AM you shouldnt even need a hose. just let it vent in the engine bay atmosphere. hany 04-23-2006, 11:34 AM ok i will do it , thank you very much. Automotive Network, Inc., Copyright ©2012
